Running Wire from Battery into Cab
Pappy
Jon
Albuquerque, NM
I was working on a project and I needed to run some wire from the battery into the cab. As usual, I started with looking for the rubber grommet that the main harness runs through. Traditionally, a small slit is cut into the outside of the grommet, and the new wires are shoved through. As I was looking at the grommet I noticed a rubber nipple. This is on the battery side, not the driver's side. It sure looked like it was there on purpose to run auxiliary wires. So, I cut the tip of the nipple off, and sure enough I was able to run a pair of 14g wires through.
I figured this might be useful for others, so here ya go.
2024 Tacoma Running Wire from Battery into Cab Grommet Nipple-sm
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Thanks for the info, that will come in handy 👍 😀
