Seat cover install NEED HELP!
Trackman
2024 Tacoma TRD sport
Clazsio covers arriving today. I can't figure out how to remove 2 elastic straps that hold down front seat back cover on the rear of the seat. I see the straps under the seat. Looks like I should be pull them over the clip, but that hasn't worked. Appreciate any help on how to remove the elastic straps. Thanks
You're 100% correct.
You have to remove the straps from the hooks under the seat. They're very tight, and I found it easier to slide them across the hook compared to lifting them above it.
Tungstenisw
Tacoma TRD OR
Make a hook tool out of a wire coat hanger. Use this to take them off AND put them back on after the install.
Frog Mack
Frog
Mississippi
24 Tacoma TRD OR, 14 FJC
With the seat back leaned forward they are very tight… lean the seat back to the rear and they loosen to the point you can unhook them with your pinky finger.
