Skinny Mudflaps = Rock Chips on Bed & Fender Flares
ridetime
Oklahoma
Same issue here on my OR with wider wheels. I added some extra PPF but didn’t go high enough. You’ll probably want to go all the way up to the gas cap. I think the only way to solve the issue is with running boards or wide sliders. My rocker area is getting rashed up too. Initially I really liked the factory “box liner” rocker guard but with the clear coat on it, it scratches really easily. Just installed running boards yesterday so we’ll see how it works after I touch everything up.
You are correct! Running boards and only certain wide ones are the only full protection. Rok Blok's are also a must. I now drive gravel roads without a care. Zero rock chips and I run dirt and gravel roads frequently. PPF won't cut it. The rocks will pit and road rash it to the point it will need replacing.
2024 Tacoma Skinny Mudflaps = Rock Chips on Bed & Fender Flares IMG_0628
2024 Tacoma Skinny Mudflaps = Rock Chips on Bed & Fender Flares IMG_0622
Mini2nut
Rokblokz splash guards offer excellent protection for the thin Toyota paint. The factory splash guards are way too small.
The only modification I made was cutting the flaps a bit shorter by cutting them right above the logo on the bottom of each flap.
I also installed a set of Rough Country HD2 running boards for the ultimate in lower body paint protection.
https://rokblokz.com/products/toyot...4-rally-mud-flaps?_pos=2&_sid=e611b4f27&_ss=r
2024 Tacoma Skinny Mudflaps = Rock Chips on Bed & Fender Flares IMG_1160
2024 Tacoma Skinny Mudflaps = Rock Chips on Bed & Fender Flares IMG_1159
SpartanCaptain
PA
2024 TRD Sport
The side of my new TRD sport got covered in stuff just from driving over a small amount of dirt. So I immedietly ordered Rokblockz Rally mudflaps. I don't know how they will hold up or if they will work much yet, but the stock ones are trash.
2024 Tacoma TRD Pro
I see RokBlokz in a lot of recommendations and I need to check them out. I was stupid and trusted Toyota and got the OEM mud flaps for my Pro. Over 1/3 of the tires sticks out beyond these generic flaps made for skinny tires. What a freaking joke - Toyota should be embarrassed.
I had PPF put on the entire truck and already I have a few PPF nicks in those areas. Without the PPF I would have my first set of chips at 700 miles. I have sliders coming and I will upgrade the mud flaps, but I need to check more of them out and see what I really want.
I would love some recommendations.
HoptownBob
Bobby
Hopkinsville, KY
2024 Tacoma TRD Sport Premium
I added Toyota cast aluminum running boards as soon as I could after getting my 2024 TRD Sport to keep this from happening. I might still replace the stock mud flaps with RokBlokz.
2024 Tacoma Skinny Mudflaps = Rock Chips on Bed & Fender Flares IMG_0901
2024 Tacoma Skinny Mudflaps = Rock Chips on Bed & Fender Flares IMG_0905
