Tail Gate Assist (SR5) ?
scottsjjackson
Scott
Ohio
2024 Toyota Tacoma SR5
I'm looking for a tail gate assist for my SR5. I have put one on every truck I've ever had and can't seem to find one for the 2024. It's similar to a hydraulic hood strut and it usually just attaches with a bracket on one side of the tail gate to assist it in lowering so it doesn't slam down if you aren't holding it. Any help would be appreciated!
2024 Tacoma TRD Pro
I thought all the trims without power tailgates had the damped lowering, but it does not sound like your SR5 does. If that is already on trims above the SR5 then it means a small market and explains the lack of options out there.
scottsjjackson
Scott
Ohio
Does it just slam down or drop slowly? The Tacoma doesn’t have a strut, it’s in the hinge mechanism itself, same as the third gen.
I’m pretty sure it just slams down. Maybe I’m doing it wrong?? I mess with it but I’m pretty sure it just drops.
Tacoflvrd
South carolina
2024 TRD sport
That’s weird. All the fourth gen’s I’ve opened the tailgates on have the drop assist or whatever it’s called.
scottsjjackson
Scott
Ohio
Just walked outside and tried it. It definitely just slams down. I’m looking to see if it’s an OEM part. But I can’t find it
2024 Tacoma TRD Pro
If your tailgate just slams open there is something wrong IMO. Check out other trucks at your dealership and if they open slowly maybe something is missing from your truck.
2024 Tacoma TRD Pro
My SR5 does not have assist either. Anyone find any good solutions?
I would push Toyota to install the hinge part that appears to be missing. They forgot to put sunroofs in some Trailhunters, even though they showed on the build sheet, so they probably just forgot to give you all the parts. First year builds of 4th gens seem to be very haphazard.
