TPMS Programming?
Dansflhti
Nova Scotia
Tire rack should have a programmer that can at least read the sensors to see if they are transmitting.
Dansflhti
Nova Scotia
And determine if the id's have the same number of characters as the oem sensors.
goin2drt
KY
Can you advise on my situation; Bought snow tires mounted on wheels with Pacific 315mhz TPMS (TireRack says these are what Toyota uses in my truck) installed at TireRack. I have followed directions on truck settings 10 times (for setting 2nd set of wheels/tires) and can not get pressure to display. I have no device for this so TireRack says go to Toyota dealer to have them "initialize" or program or otherwise make the new TPMS talk to the truck. I have read the TPWS part of my owners manual and it does not exactly correspond with my truck settings menus. I Have a TRD Sport with what I believe is the 12.3" digital dash display. I have an appointment with a dealership but would be happy to cancel if you have any ideas for me. Ive tried driving all around and resetting and nothing works. Thanks!
Highly unlikely they installed OE Pacific sensors as those are quite expensive and TR usually only uses "programmable" sensors. IF they would have sent the correct sensors either the OE or Programmable programmed to your year, make and model then they would RELEARN via the truck that you have already tried. The dealer CANNOT program them for you. All they are going to do is scan them for the year, make and model. IF they scan correctly then they can manually upload the ID's via OBD but again this is highly unlikely as if that were the case the truck would do the relearn via the truck settings that you tried.
My guess is TR screwed up and sent you the incorrect TPMS, In that case they need to send you correct ones because without knowing the exact brand they used you will not get them programmed. If they did install Pacific then they installed the wrong ones,
NOTAFORD
Andy
Massachusetts
2024 Tacoma TRD Sport 6' bed
Wow! Ok, the invoice says Pacific 315, but a customer support person told me Redi Sensor... I kind of knew this would happen. Now the dealer will charge me to try to program them, fail and try to convince me to let them dismount and make it all work for $800! I wish I had skipped the TPMS in the snow tires! I am a good TPMS myself!
rijc99
4G Tacoma OR Premium
Redi is a common brand. Can’t you go to a local tire shop and see if they’ll program the sensor for a small fee? Takes a couple of minutes max.
M1KL83
Tacoma TRD OR 6MT
Thanks for all the help.
Found dealer that did a good price for oem tpms 42607-0E090 at $72 CAD each.
KAL Tire put them in 2nd set of steelies with winter tires, before driving away I used dash board vehicle settings selected tpms, then Tire Set Switching, selected Set 2 and left garage. Within 5km the yellow tpms warning light turned off and the truck registered the 2nd set.
Hopefully it stays that way.
MHG
Mark
Long Island
2025 TRD Offroad
Where in the MID do you do anything with the TPMS sensors like reset after airing back up. I went though the menus yesterday and could not find anything.
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
Settings
Vehicle Settings
TPWS Setting
Tire Pressure Setting
