TPMS Settings Question
Tom Sellick
Tom
Ontario
2024 TRD Pro
Now that it’s starting to get cold up in the Great White North, I’ve noticed my TPMS giving me low pressure warnings the last couple of mornings. Tires were set to the door placard at 30psi. The pressure on the dash was showing the tires to be at 28/29psi. Got me wondering why that would trigger a warning. I dug into the settings and found the TPMS settings. It appears you can set the pressure you want the tires to be at and I think mine was set to 35psi? I believe I changed that back to 30psi. It walks you through setting that for the front and rear tires. Am I missing anything else? I have the TRD Pro…are others going with 30psi?
thanks!
bluecrush.taco
Seattle
I had the same question. I have the stock TRD Off road and the dealership had it at 40psi. Been driving it around like that for a few weeks. Then I brought it down to 30psi per the door sticker and it triggered a warning. I didn't realize you can change the setting either but I it's set to 30 now.
I also don't know if I'm missing something but it seem a dealership error. Surely the door sticker recommendation is correct right?
Tom Sellick
Tom
Ontario
2024 TRD Pro
I would think so in regard to the door sticker? Maybe others may have an opinion. When I had my 4Runner the dealer always set the tires to 35. Memory says the door sticker was 32. They said it gave a better ride but it seemed the tires often seemed to wear more in the middle.
I’m just hoping I set the pressure properly :). I think I did….after you set the front tires and back tires it took me to a screen to confirm “ok” which I did. So assume it worked.
Do you make that setting change in the instrument cluster or through the screen?
I usually run a couple of psi higher than recommended, just so I don't get low pressure warnings every time it gets a bit colder. So my Pro is at 32 front/rear, although it is getting colder, so they are probably closer to 30 psi now. The rule of thumb is 1 psi drop for every 10 degrees F lower.
I didn't know you could change the trigger point, which is cool. I will have to make sure mine is set to 30 psi also. Thanks for the tip.
Kdbradley85
Kevin
2024 Toyota Tacoma TRD OR MT
Assuming you have the stock wheels and tires, your tire pressure should be around 30 psi as it says on the door sticker. I had the exact same thing with mine. My tires were at 50 psi when I got it from the dealer! I lowered the pressure to the appropriate level, and on the first cool night we had here, my TPMS was going off. It's cool that you can adjust the settings. I've never seen that before on any other vehicles I've owned. If you have access to a flat concrete slab, you can eye how your tread is laying on the surface (it should be flat and even across the entire tread face). Mine Fluctuate with driving and outside temperature between 27 and 32 psi, but if you get nitrogen in your tires, that should reduce the amount of pressure fluctuation significantly.
bsquaredMTB
Ben
El Paso, TX
For what it's worth there's an option in the settings to set the desired tire pressure. When I go off-roading, I set it to 20 so that I'm not constantly getting those low pressure warnings. Similarly, you can set it to 30 once you have your tires set at 30 psi.
bigd9247
WA
2024 Tacoma TRD OR Premium
I had the same issue. My door sticker says somewhere around 30psi (can't remember the exact number right now) but the instrument cluster was set at 35psi. It caused a low pressure warning in cold weather. I changed the instrument cluster to 30psi and no warnings since.
