I have anticipated this and have purchased a cut of 3m ppf to put on that area. I need to make a template and get it done before my wheels get here
I weighed the bronze wheels at just over 33 lbs each. I also had the opportunity to weigh the 18" OR hybrid wheels since I was sent those by mistake, and they were nearly identical weight-wise (I think @Lando was interested in doing this potentially). The tires that you select are likely to have a much bigger impact on gas mileage than the weight of the wheels themselves, but it all adds up.Did you by any chance throw them on a scale?
I have the Trailhunter wheels on the way, I got the peak 1 inch spacer lift I’m going to install, went with 275-70-18 tiresOk cool. Yeah, I went with 275/70R18 tires, which are 33.2" diameter, so I think they're gonna be tight. The spacers might give me a little more breathing room, but I intend to install the wheels first to see how it goes.
Nice! I haven't yet decided to install a lift. If I do, it will be the wescott lift when I also get their rock rails.I have the Trailhunter wheels on the way, I got the peak 1 inch spacer lift I’m going to install, went with 275-70-18 tires
I bought the 1.25" front leveling kit from Peak and never installed it. That size tire is almost perfect for these trucks on the stock suspension. I kind of like the rake on these trucks as they sit, so I didn't really want to install the spacer lift unless I needed to. I'm really considering one of the new Fox suspension kits that just came out, but that's a big spend. Maybe in another year or two... we'll see. Congrats on the wheels! You made a good choice.I have the Trailhunter wheels on the way, I got the peak 1 inch spacer lift I’m going to install, went with 275-70-18 tires
PT280-35221-5F and no, they don't come with the wheels and must be ordered separately.Do these come with center caps or do I need to order them separate? If separate does anyone know the part number? Sparks parts just called and told me they’re in stock and I can pick them up in the morning since I’m local.
Thanks I just ordered. Hopefully they are in stockPT280-35221-5F and no, they don't come with the wheels and must be ordered separately.
