TRD decal removal from rear quarter panel - tips?
AKYLEP
Adam
Arizona
Anyone have any good tips for removing the TRD decals on the rear quarter panels?
Flyfish007
NJ
2024 TRD Sport
Normally a little heat would do the trick but these decals were a PIA. I had to use an eraser wheel. Took about 10 min.
  • Like
Reactions: JED
goin2drt
KY
Honestly I did mine the day it came home. It was sitting outside in about 80 degrees. They peeled right off and left a tiny bit of this white residue that came off with my thumb just rubbing it. Took no joke 5 minutes for both.
Dieselfxr
NE Tennessee
1999 TRD and a 2024 TRDOR with a deposit
I removed mine after having the truck for a week. About a 80 degree day and was able to get an edge started with a finger nail. They came right off although not in one piece. Very minimal residue left and it came right off with minimal effort. When I got my 99 TRD I removed them after about a year and they were much more difficult to remove.
AKYLEP
Adam
Arizona
Thanks for the tips. I didn’t take them off my 2014 TRD OR, but it was Canyon Stone Silver and it kinda looked okay. This one I have had just over a month and it just doesn’t look right so they’re coming off.
Deleted member 5766
Guest
Let it bake in the sun, slow peel, adhesive remover and quality microfiber for cleanup
rideradk
Tom
Glenville NY
2024 TRD Offroad
I removed them after 3 months. It was a 90+ deg day. Driver side was a pain. I was picking tiny bits off with my finger nails to the point I got so frustrated I dug out a plastic scraper. No amount of adhesive remover helped. Ended up scratching the clear coat. I then bought a eraser wheel to do the passenger side. Even that dulled the clear coat. Regardless, it still looks better and in a year or so when I get some more scratches on the truck I won't even notice the ones I made.
DarthTaco
Paul
24 TRD Sport
I removed mine the first day I had it home. It wasn't possible to peel them off, the top most film would peel off but leave behind a bottom layer including adhesive. Had to resort to a pinstripe remover. Which worked great, but I'm a noob so I screwed up the top coat a bit. Should be correctable though.
Pin stripe remover is available for cheap on amazon. Works great, go slow.. take your time.
TrashPanda
Brad
Alabama
2024 Tacoma TRD OR Premium
This decal is a bitch to remove. I got one down in 90 degree heat after about 2 hours of tedious adhesive removal.
HCTacoGuy
Jerry
Pa
2025 Tacoma TRD Sport
Use the 3m wheel on a cordless drill. Took me less than 10 minutes to remove both. Do not take the outer layer of the sticker off before starting with the wheel.
