Fireguy67
Klaus
British Columbia
Installed a new set of hydraulic hood assist rams today from Rough Country. Took about 3/4 of an hour. I have the hood insulation on my Sport Premium so had to romove some clips and it took a bit longer. Should have come with something like this system from the factory ( maybe in 2025?). Far better than the old prop rod.
2024 Tacoma Hydraulic struts hood assist system installed IMG_3976
goin2drt
KY
Looks good. I will do the same. You said your sport premium came with that hood insulation? I hope mine does.
av8r
Southern Tier NY
too many
Just curious...what's wrong with the tried and true prop rod? It'll never lose pressure, leak or try to spring open at 80 mph on a hot day.
Fireguy67
Fireguy67
Klaus
British Columbia
Absolutely correct. But It is just something I like. Had them in my 2 nd gen. I always found the prop rod got in the way when I wanted to do anything on the engine. Just personal preference I guess.
goin2drt
KY
I mean I have had them in about 15 cars, hundreds of thousands of miles and none of those things ever happened. You better keep your radio turned off, it my spark and cause a fire while you are driving 55 down the road.
av8r
Southern Tier NY
too many
Great answer. I honestly didn't know if there was an issue with the prop rods on these. I've never owned a toyota truck so this was helpful.
2024 TRD Sport-Bronze oxide.
OP, can you give info on your hood insulation? Where did you get it, and have you noticed differences since installing it?
Fireguy67
Fireguy67
Klaus
British Columbia
The hood insulation came as part of my premium package. I can’t say if it’s really made a difference as I haven’t driven one without the insulation. I don’t know if it really serves a purpose ( maybe a bit sound-wise) and to tell you, the truth it is rather flimsy. It was a little challenging, taking out the clips without breaking the insulation, but I managed to do it.
Jdunlap12
Justin
Charleston, WV
2024 Tacoma SR5
Is there a part number on your hood insulation?
Fireguy67
Fireguy67
Klaus
British Columbia
Sorry it was part of the premium package so I do not have a separate part number for the insulation. I wll do a little research and try to find out.
Fireguy67
Fireguy67
Klaus
British Columbia
So I did some research on this hood insulation piece. Keep in mind that I am up here in Canada so we are talking Canadian dollars. Part # up here is 53341-AK010. Price ( are you sitting down?)-$741.86 plus tax!!!!! ( just for that one piece of insulation!!)
Fireguy67
Fireguy67
Klaus
British Columbia
Sorry jdunlap12, just noticed your last post. Seems to be the same part #.
907Yota
Marty
Alaska
1985 Toyota Xtracab 4WD, 1990 4Runner
My wife's car has prop rods, my Toyota truck does not. I can open her hood one handed and mine takes two. I often have something in my hand such as a flashlight, jumper cables, etc.
Prop rods are nice and I wish they came stock like they do on the Nissan.
Lando
Is drilling required for these? If so I’m good with the prop.
My old American cars required neither a prop rod or hydraulic shocks that would fail. I remember in the 80’s first seeing imports with prop rods and thinking, “how cheap”. Suppose I was right as it became pretty much the standard.
