DeadSetMonkey
- Joined
- Sep 5, 2024
- Threads
- 8
- Messages
- 28
- Reaction score
- 6
- Location
- Denver, CO
- Vehicle(s)
- Toyota GR86, Rivian R1S, Vanagon Syncro Westy
Help.
I have a 2024 Tacoma Trailhunter. I have the Rigid D-SS Pro Ditch lights.
They came with a wiring harness, a toggle switch, the lights, and the mounting hardware.
I read the light specs and see that they draw 3.8Amp. So was wanting to use the Aux3 OEM switch (5A circuit).
So, I mocked it all up and then tried a "dry run" in the truck to be sure everything was going to work - no light.
What am I missing?
I spliced the rigid wiring harness to the free wires on the pigtail
- Rigid red wire to white from pigtail
- Rigid black wire to ground white/black strip from pigtail. (heatshruck solder sleeve covered with heat shrink wrap).
I inserted the rigid switch, into the circuit, mated black wires to gold spade on switch back. Red wires each to one of two silver spades on the back of the switch (will cut/splice toggle out at final install).
I plugged the pigtail into the Aux port (driver's side, near windshield washer filler).
Turned on the truck, turned on the Aux3 switch in the dash - no lights
(toggled the rigid switch on/off too, hard to tell which way is on/off on the little switch).
What am I missing?
See attached photo of the wiring run and parts etc..
Photo shows the bits cut off and the bits used to make the splice with the OEM pigtail.
What am I missing?
What am I missing?
