Any reason not to use the factory speaker connector?
Scarletunic
East coast of Canada
2024 Trd Off road tacoma 6 mt
As the title suggests. Can I cut the following piece from the factory speaker to use as a harness for the new speaker?
Also. I'm assuming because I'm new I can't post a pic. I'll post it in the comments.
Scarletunic
Scarletunic
I still can't post a pic. Can I cut the factory plug/resistor/wires from the original speaker and use them on the new?
Vidman
Rick
Mass
If your changing speakers just get the correct adapter..that’s what I did worked out great
Scarletunic
Scarletunic
Thanks. I've been looking at that but living on an island on the east coast of Canada slows things quite a bit.
UT
I'd imagine if you know what the wires do/go to yea, you can reuse them. However, I'd be worried more about if the power/impedance matches what I'm replacing the factory speakers with.
Scarletunic
Scarletunic
I'm talking about cutting the connection out of the old speaker. Connect the two speaker wires from that to my new speaker and plug it back in.
Cabby30
CA
2024 DCLB TRD OR
Make your own pig tail to connect into the factory connector? That way no cutting and easily reversible (no splicing; although splicing isn't difficult).
OhioSolar
Chip
2022 Ford Mustang Mach 1, 2024 Toyota Tacoma, 2017 Mercedes AMG S 63 Convertible
Speaker wire harness adapter is Metra 72-8109 front & rear. Front 6.5" speaker adapter is Scosche SAT69 & rear 6.5" speaker adapter is Metra 82-8148.
