OEM Tonneau Cover leaking šŸ˜±
Randyg
Randy
OK
I hope this is only a temporary condition - my OEM cover leaks on all sides. It appears there is significant leaking along the tailgate, which I assumed would be the weakest seal. Tailgate seal rests on tailgate per OEM instructions. Both sides have runs all the way to the front, albeit appear to be minimal. The corners by the cab (the part that bolts down) leak the most. Parked in light to moderate rain for a few hours and then driven a few miles in light rain. I canā€™t tell exactly where one leak is coming from but one of the drain tubes is wet on its outside.
ridetime
Oklahoma
Unfortunately these types of covers are just going to leak a little. Yours looks about like mine after a car wash or drive in the rain. The good news is that although it gets a little wet around the edges it should still keep your cargo dry.
I went with the ultra flex undercover. It is a high quality folding cover that was professionally installed and it still seeps a little water in the areas you point out. If your looking for powder keg dry you might want to look at one of the Diamondback covers. diamondbackcovers.com
Randyg
Randyg
Randy
OK
Thanks for reply. I did look at DB but wanted the ā€˜full openā€™ mode this offered. I did expect some leaks but this was more than expected. Also, I am concerned the front corner leaks are due to the drain tracks being overwhelmed for some reason. If, as you say, itā€™s normal for this (and similar) covers, Iā€™ll ignore and adjust.
Goriders
2024 Tacoma Sport Plus
Mine leaked in a heavy rainfall. But overall itā€™s not bad in lighter rain. Good enough for what I need.
Dirt
Greg
Eastern OR
Randyg, I had the OEM cover installed by a dealership. Gotta say it works better than the others I've had, that said it does not leak as badly as yours. The front corners have small holes that couldn't be plugged because of the design are my biggest culprits, but I've not had water on the outside of the drain tubes or that much standing water. Winter is coming so we'll see.
Randyg
Randyg
Randy
OK
As an update, I discovered these. I dried out the bed yesterday and then exposed it to rain again (weā€™re getting a ton here) for a 10 minute drive. Puddles in the bed. Biggest leaks are at the tailgate gaps on either side. Canā€™t do anything about those. Gutters up by the cab were all wet. A ran my fingers around the front of them and these rubber ā€˜padsā€™ fell off. Looks like double-sided tape was not very water resistant. I will have to take the cover completely off to figure out what their job was. Perhaps they were to seal the ends of the gutters. Anyone have any idea?.
TNTexas
Houston, TX
2024 Tacoma TRD Sport 4x4
I found one of these on mine as well. I found it around where the cover is secured to the rail. I couldnā€™t figure out where it came off of. I did have some leaks around corners after some moderate rain this morning. There are definitely gaps where the cover meets the front bulkhead as others have pointed out. I put some foam there to cover the gaps.
TNTexas
Houston, TX
Just a quick update on this.ā€¦With additional gasket tape added, it appears that leaks have stopped on one side. I still have water (albeit much less) on the side where I found loose black foam piece. I added more gasket tape on this side and see if it helps. The loose black foam piece certainly does something, but I canā€™t find where it came from. I am hesitant to remove the cover and risk more water coming in the next time it rains.
Randyg
Randyg
Randy
OK
I am willing to bet the foam is from the front end of the gutter. Here is a pic of the back end. The back has a small plastic cap but the front has the draintube adapter cap. Both caps, for some stupid reason, are open on the ends and water can drain straight out of the gutters ends. So on the front, they attach a piece of pretaped gasket material over the end. In the back they donā€™t. I originally thought maybe that is why I was getting a lot of water in my bed. So I glued foam on the back ends as well. When I realized it made no difference I took the foam back off. Thatā€™s why you can see some glue residue on the end of the gutter. Since the truck sinks forward a bit the water flows to the front and I guess is not needed in the back. If that piece of foam came unglued from your front gutters, thatā€™s definitely where some water is coming from.
