TRANSMISSION GOT STUCK IN SECOND GEAR ⚙️
Tacodonal
Tacodonal
Donal
2024 tacoma
I recorded this video the guys can have an idea.
I'm going to drop off my truck next week because I'm pretty sure something is going on when I put in reverse, I heard a hit sound. 4gen taco not shift
Tacodonal
Tacodonal
Donal
2024 tacoma
That's pretty fast service. Is the 'new' transmission OK now?
Hunmm, not sure, it drives better than before, but I have an appointment next week this week about the shift from D to R, because it makes very hard sound like something it hitting it he tranmission.
timetoeatpotatoes
A
CA
2024 Trailhunter
Interested to see what ends up happening but Im wondering if they did not actually replace the transmission? 2.5 hours (considerably less than that, once you factor in time to deliver from the other dealer) is pretty quick for a swap.
Tacodonal
Tacodonal
Donal
2024 tacoma
Me interesa ver qué sucede, pero me pregunto si en realidad no reemplazaron la transmisión. 2,5 horas (considerablemente menos que eso, una vez que se tiene en cuenta el tiempo de entrega del otro concesionario) es bastante rápido para un cambio.
[/CITA]
●Día 1 la dejó en el taller y ordenaron la nueva transmisión.
@●Día 2 reemplazaron la transmisión de 8am a 1:30pm
bking
Bernie
2021 F150
Could be. They likely had the old one out when the new one arrived
My transmission is in the TSB and mostly if shifts fine. But I do get those hard shifts into reverse and they sound like what you describe @Tacodonal - like someone hit the transmission case with a hammer. It is hard to see how that is normal, but since it still moves I guess Toyota says that it is.
It seems strange that a new transmission was already at another dealer and even stranger that it is not working right already.
TrustButVerify
Several
They replaced new transmission in 6 hours which is crazy how fast was it, and I'm still wondering because it makes something like hit 80% when i put it in reverse.
This happened at 2100 miles
What does this even mean? 80% of what? What is "it?" The transmission was fast? The repair was fast? What is hitting what?
Did you hit 100% of something before typing this?
thefinalstraw
Massachusetts
2024 Underground TRD Sport 4x4 Premium
based on the quote above in spanish, i think OP is not a native english speaker and using google translate to post.
my interpretation based on that assumption: he's shocked by how quickly they replaced the transmission. and now with the new transmission, 80% of the time he shifts into reverse, it makes a noise that sounds like the transmission is being hit with something, the same symptom @TacoFreak described.
TrustButVerify
Several
The machines got us the Spanish to Englishish, but the missing 5% was Englishish to English. It makes much more sense more. Thank you.
Gfenza89
Gary
2022 tacoma sr5
Mine does the exact same thing SLAMS. Into reverse
thefinalstraw
Massachusetts
clearly a symptom of something, frustrating that toyota has the gall to call it normal. has yours always done it, or if not at what mileage did the symptom start? i am at 500 miles with no noticeable transmission issues......yet.
Gfenza89
Gary
2022 tacoma sr5
That isn’t the only issue with mine, it also is bad driving at low speeds, clunks, jerks, bangs, shudders and vibrates at low speeds, it’s so embarrassing I won’t let anyone drive in my truck. To answer your question everything was unicorns and rainbows until 500ish miles then all the problems started
thefinalstraw
Massachusetts
sorry, i'm sure you've discussed all this elsewhere already, but still no codes on an OBD reader?
how many miles now, and when was the last time a dealer looked at it? did you try a second dealer? i can't fathom them just ignoring such symptoms, code or not.
