Skinny Mudflaps = Rock Chips on Bed & Fender Flares
HBNARO
Scottsdale Az
2024 TRD PRO in route
This ain’t just a Tacoma problem …
Yep. I have a 2019 991.2 GTS. It has factory ppf, but I added some magnetic black carbon fiber looking protection over the top of that. Too bad some of the taco area taking the beating is plastic because a similar magnetic solution would have been cool.
baller
myrr
WA
24 Trailhunter
Going to try PK389-35R50-P1 on my TH soon - will report back with results.
Finally got the set of these today - much wider than the useless stock ones. Should have them mounted up tonight. Thanks Franko for the part #!
I'd love to see a picture of them on your TH so I can see how they look with the TH/Pro flairs.
myrr
WA
24 Trailhunter
Will do - the part numbers on the individual flaps match up - should look just like Franko’s I’ll snap a pic.
myrr
WA
24 Trailhunter
Makes you wonder if the 25s will have the “upgraded” flaps. They really should.
myrr
WA
24 Trailhunter
New mudflaps on without incident. Much better than stock lol. Came with screws I didn’t need, just reused the hardware from the original mudflaps.
2024 Tacoma Skinny Mudflaps = Rock Chips on Bed & Fender Flares IMG_3021
2024 Tacoma Skinny Mudflaps = Rock Chips on Bed & Fender Flares IMG_3020
2024 Tacoma Skinny Mudflaps = Rock Chips on Bed & Fender Flares IMG_3019
2024 Tacoma Skinny Mudflaps = Rock Chips on Bed & Fender Flares IMG_3018
Franko Manini
Frank
Victoria, BC CANADA
Yup. Looks exactly like mine. Notice how the flap edge comes out parallel to the outside edge of the flare? That’s the way it ought to be.
These are the flaps with the part number that ends in R50. They are wider than the set that has the PN that ends in R00.
I hope they help you out man.
GSSeattle
Greg
Seattle
Okay guys - that didn't take too long. I had a meeting get cancelled, it wasn't raining, AND it's not dark here just yet.
So I popped outside and pulled off the mudguards.
Part Number Front: PK389-35R50-F1
Part Number Rear: PK389-35R50-R1
Both parts also have stamps saying Made in Canada. Which I thought was really weird. I did a quick search and found sites that you can order from but nobody has pictures of these parts.
Frank
Thanks @Franko Manini for pulling and getting part numbers! PK389-35R50-P1 fit my TH well, extending out as far as the fender flares.
