Speaker Replacement Experience...
webshot
Northern California
I recently went down the road of attempting to upgrade the speakers on my 4th Gen JBL on the cheap. I did not want to mess with an external amp if I could avoid it. I was just looking for more clarity and highs from the music.
I did properly seal all speakers using foam tape as required to achieve optimal bass.
I wanted the option of going back to stock if needed.
Here are the parts I used…
Rear 6.5”
Mids 3.5”
Front Doors 6”x9”
Lessons learned…
  • Tape off around all work areas to not scratch the interior plastic. It is soft!
  • Just installing the rears and mids provided a very small boost in highs.
  • The rears still sound a little muddy and are underpowered from the stock amp
  • The Metra wire adapters work with the rear door, front door, and mids in the dash BUT are wired incorrectly reverse polarity!!!
  • The new 6x9 speakers were removed. They did not provide any value. The 6x9’s in the doors are filtered for low frequency only by the stock system. The factory amp will start to distort or clip if turned all the way up…
  • I tried 3 different 6x9 spacer brands. All of them require drilling to match up with the stock screw holes in the door. Also they may have "ears" that need to be cut down to fit the door panel back on.
  • The mids I installed in the dash do not fit exactly but can made to fit if you are creative.
  • The rear doors are somewhat shallow between the face of the door (metal) and the door panel. If you have any speakers with tweeters that stick out in the center, they may hit the door panel with the spacers you purchase. I tired 3 different spacer models from amazon, the Metra spacers I used had to be heavily modified to set the speaker back far enough.
  • When fitting your speakers in the doors, ensure you have the windows down so you know the speaker magnet clears.
Final Opinion: The juice is not worth the squeeze!!
If you are going to upgrade your JBL system, spend the money and do the WHOLE thing.
Useful resources: https://www.tacomaworld.com/threads/4th-gen-jbl-replacement.830793/
hoodouken
Las Vegas
I've noticed a good amount of meh reviews of the sound system which is really disappointing. Especially being shocked how good the stock system is in our 2021 Outback.
When I got my 2004 STi in 2005 the first thing I did was rip out all the stock cabling and stereo components. Drilling, mounting and busting my fingers got it all done in a couple days and it sounded, amazing. That was my last time upgrading my system and I never wanted to do it again. So again, disappointed in the upper tier Tacos don't have better sound quality.
Sorry bud it didn't work out.
Nice writeup, thanks @webshot.
I was wondering if there was any way to improve the sound without a complete redo. It appears that I should just live with it as it is for a while and eventually replace it all. Do you think that we can keep the OEM head unit and just replace everything else?
My 12 year old JBL system in my Tundra is pretty decent, but like everything else I guess the race to bottom has struck again.
2024 TRD Sport-Bronze oxide
I would like to upgrade the amp, but I'm waiting for one that still lets you make adjustments after everything is put back together.
webshot
webshot
Northern California
I'm waiting to hear more positive feedback on the Beat-Sonic solution. This may be the better option with or without speaker upgrade.
Quickreply1
Tim
Oregon
None
Update: I upgraded the four door speakers to 6 3/4” kicker two way coaxial speakers. It sounds marginally better, slightly louder and a bit punchier with the base, but nothing I think anyone would notice. I personally am glad I upgraded and added some sound proofing. The sound overall is better with the added base.
Original: I have the base version of the stereo in my TRD off-road. I tried installing some 6x9s in the front and some 6.5 in the rear and hey did not fit due to the wrong/missing adapters from the retailer I ordered from.
I sent everything back and just ordered via Crutchfield. They seem to have some good recommendations on front and rear door speakers now and have appropriate adapters.
Ordered (4) 6 3/4” speakers for front and rear. The mounting adapters were included for free and I ordered the speaker plug-ins from taco tunes as they weren’t available at Crutchfield yet. I’ll report back once I get everything installed and see if the juice is worth the squeeze for those of us in the non-JBL camp.
webshot
webshot
Northern California
Update: Added the Beat Sonic amp yesterday - This is the way!
With my upgraded rear door speakers it sounds pretty darn good!
I would suggest if you install the Beat Sonic amp that you turn up the rear gain higher than what they show in their videos.
evlfred
Monte
Idaho
ok so what all speakers and components did you end up being happy with?
Fiigtaco
TRD OR
where the 3.5s a direct replacement? i ask because I've seen people use 3-3.5 with a adapter up to a 4" mid
webshot
webshot
Northern California
(Note all my posts in this thread are for the JBL system only!)
I mostly kept the stock speakers except the rears, and I may switch back to the stock in the rear. (See the first post in this thread for what I installed in the rear.)
Recent conclusion... Post Beat Sonic Amp install
I found a lot of people knock the stock speakers due magnet size, but after installing the amplifier, the stock speakers come to life. Magnet size has nothing to do with it. People are mistakenly comparing the huge magnets on old designed "Ferrite" speakers vs. stock which are "Neodymium".
Neodymium speakers hit harder when powered properly. You can really feel them after adding the amplifier. Night and day difference.
I'm doing more research on "Better" neodymium speakers now. There are some limited options out there. I'll keep updating this thread as I discover and try better options.
webshot
webshot
Northern California
Stay with stock and add the Beat Sonic amp. You will not be disappointed! (This is assuming you have the JBL setup)
Muckle
NA
Does the amp really add that much more depth and clarity to the sound, or just increase the max volume?
I’m routinely between 20-30 on the volume so never maxing it out (I think it goes up to 50 or 60?).
evlfred
Monte
Idaho
I am wondering about the beat sonic for the JBL, how is it adding amplification if it's preamp? (before the JBL factory amplifier)
webshot
webshot
Northern California
No it is an actual amplifier. I believe the only amplifier in the stock setup is contained in the head unit itself. You can read the specs on their website.
2024 Tacoma Speaker Replacement Experience... 1735586043529-2c
