TRD Sport spare tire wheel size?
2024 TRD Sport-Bronze oxide.
My Sport has the full size, albeit temp spare. The size tires on the truck are 265/65R18. It's too cold and snowy to crank down the spare and look at the wheel right now. Is the spare wheel an 18", where I could have a regular tire mounted on it, so I could drive a good distance at highway speeds if I had to use it? I've seen some reports that say it's a 17".
Brian2011
MASS
2024 Trail hunter
the same overall tire circumference equivalent, scratch that think the sport comes with a 17inch rim, but would assume the tire on it is the same circumference of the factory setup
EastonTaco
Venice FL & Easton PA
My TRD Sport has stock 18 inch wheels and the temp spare is on a 17 inch rim. The spare is about an inch smaller than the regular tire circumference. Its an odd looking tire with a balloon like sidewall and real shallow tread. I would not want to drive on this spare over 50 MPH or while towing or in bad weather. Don’t get me wrong I love my truck but the spare is a real looser and one of the first things I changed.
EastonTaco
A bit more info, the stock tires on stock wheels are 31.5 inches in circumference. They are the same overall with as the spare due to the ballon shape of the spare. The stock tire fits perfectly under the trunk and does not hang any lower than the spare.
So, if I wanted to use the spare steel wheel, I wonder could a 265/70R17 be mounted on it and that would bring it up to the same diameter as the 265/65R18 OEM's? I read that it is bad on the differential to have a smaller diameter tire/wheel running on the axle vs. it's mate on the other side.
EastonTaco
I don't know if the 265/70R17 would fit on that rim. It is the right tire size at 17 inches, but if you pull the spare down you will see that it's an odd looking tire and I don't know if that rim was made specifically for a temp type of tire. I found a used stock TRD Sport wheel for $190 on eBay including shipping. It was a take off from a vehicle that the owner switched rims so it was essentially brand new, and I was able to get a Cooper light truck 265/65R18 blem that is nearly identical to the stock tire for $145 mounted and balanced. For not too much money I got a full size spare to identically match the stock wheels and now I have an extra rim if (when) the wife mangles a rim parking.
Thanks for your info. It looks like I'm going to have to go your route rather than try to cobble something together with the OEM spare wheel. You're probably right, that spare wheel is not designed for a regular tire to be mounted on it.
tonymac
anthony
waco, tx
2024 TRD Sport
The spare wheel/rim is nothing special. You can mount another tire on it. The tire on it is a 245/75 R17.
With that said, I pulled it and bought the same rim in 18” and mounted the same tire I put on the truck (bought 5).
rijc99
4G Tacoma OR Premium
The white door jam sticker should say what size your spare is
rijc99
For reference. Some Tacos do come with a full spare. This was off a Trailhunter.
2024 Tacoma TRD Sport spare tire wheel size? IMG_2470
Well, that's very interesting. Thanks for posting. My Sport has the 17" spare. Wonder why some have 18" and some have 17" What's Toyota's reasoning with the spare, Sport vs. Trailhunter when the OEM wheels on both trucks are 18" ?
2024 Tacoma TRD Sport spare tire wheel size? spare
Brian2011
MASS
2024 Trail hunter
the difference is minimal.
2024 Tacoma TRD Sport spare tire wheel size? 1737644914173-29
