In bed molle sytems
Irvin
JC
I really like my Victory 4x4 molle panels. I have the back and one side. The passenger side doesn't need drilling, so that's the one side I installed. I also have the Victory 4x4 front skid plate, and I'm eagerly waiting for their winch bumper.
The driver side panel requires drilling? I hadn't seen that, bit of a letdown
Victory 4x4
Daryl
Portage, MI
'24 TRD Pro
Yeah, driver side is totally blank. No storage box to use the bolts of. Bed is composite though, drills way easy.
Irvin
JC
Well dang, there goes my option of ordering your panels. Definitely not drilling.
emerica243
Matt
PA
Fusion
Wouldn't it make sense to use the bed rails as the mounting medium?
Bravada
S.E. Texas
2024 Taco Limited i-Force Max
If you watch the install video it's really not that big of a deal for the three drilled holes. As soon as I have a need for it, I'll be getting an additional side panel for the drivers side.
emerica243
Matt
PA
Fusion
My guess is people who maybe lease who may not be sure they are looking to own it, are looking for full bolt on and removable options without modification on the vehicle
emerica243
Matt
PA
Fusion
I wonder on the driver side of there was attached rubber blocks / padding on the bottom to support it you wouldn't need to drill them in. Thek being supported on the rail at the top should be enough . That's how I'd design it anyway
Victory 4x4
Daryl
Portage, MI
'24 TRD Pro
I'd say don't install the driver side panel then. I think most, like ours, are drill only.
emerica243
Matt
PA
Fusion
I'm not bashing, just stating different ways these could be designed.
Does your passenger side and front cab peice work if there's an OEM tonneau cover?
Victory 4x4
Daryl
Portage, MI
'24 TRD Pro
So you can just install ours that way if you wanted to source the rubber bumpers, and it's a method we've used before, but depending on weight on the panel it can vibrate.
Victory 4x4
Daryl
Portage, MI
'24 TRD Pro
As long as the rails don't get moved down for the cover. I don't believe they do this on the OEM taco cover.
emerica243
Matt
PA
Fusion
Unfortunately that is the case from the OEM cover. Side rails are lowered. Perhaps the rear isn't will have to further inspect.
2024 Tacoma In bed molle sytems 20250124_171433
2024 Tacoma In bed molle sytems 20250124_171414
