Attempt at Charging the Center JBL Speaker without Hearing it...
webshot
Northern California
Like a lot of you I am not a fan of the JBL center speaker and prefer that it is silent, but still charging.
I pulled the speaker and its enclosure out of the dash to see what I was dealing with. I'll let the pictures do the talking...
2024 Tacoma Attempt at Charging the Center JBL Speaker without Hearing it... 1738121630928-zz
Blue painters tape over the audio connection leaving the positive and negative connections only.
2024 Tacoma Attempt at Charging the Center JBL Speaker without Hearing it... 1738121837840-a6
I'll report back after testing for a few months.
Interesting - keep us posted on how that goes.
I don't like the removable speaker bias either, but when I removed mine I thought that the sound was even worse. Maybe I need to try that again.
webshot
webshot
Northern California
If you have not upgraded to the Beat-Sonic amp yet, you may not want to do this.
MERAKIAUTOWORKS
Joshua
Anaheim, CA
Super popular mod within the past 2 weeks.
IF you don't want that JBL middle speaker, I'd be glad to take it off your hands.
-Josh
Josh256
Toronto, ON
2025 Tacoma TRD Pro
I was misled by the 5-pin dock wiring harness -- the actual 4 wire supply feeds to the side (12V+/-, Center +/-) where it mates with a small circuit board.. Pull the dock. You could remove the two center channel leads from the connector keeping the 12V supply however I *think* the JBL amp re-EQs the whole system when the JBL center is present:
https://www.tacoma4g.com/forum/threads/jbl-replacement-center-channel-speaker-prototype-diy.10601/
2024 Tacoma Attempt at Charging the Center JBL Speaker without Hearing it... IMG_3184 3 Medium
2024 Tacoma Attempt at Charging the Center JBL Speaker without Hearing it... IMG_3182 2 Medium
