Removable JBL center channel speaker.
Miqie
2024 TRD Sport-Bronze oxide.
I have not removed mine yet to play with it. It can only be paired with the truck's system? I assumed you could pair it with any Bluetooth source.
bresna
Kevin
2024 TRD Sport
There is a USB-C charge port on the side so you can use it outside of the truck.
2024 Tacoma Removable JBL center channel speaker. 1716822185125
Abelo19
Adam
Buffalo, NY
2024 Tacoma TRD Off-road Premium
I’m also curious if the radio can be played through the speaker when it is disconnected. I enjoy going to the drive in and think it would be a neat feature to have in the truck bed with the wife and I chilling watching the movies.
Unfortunately I don’t believe it can be. I’ve had my ā€˜24 Tacoma for a little over a month and 5,200 miles and still have not found a way to connect to the vehicle when removed…
Voodoo452
Northern Nevada
2024 Tacoma TRD Pro
Anyone make a 3D Printable filler for gaping hole in the dash? For those who chose not to leave/user the speaker in the truck?
Airborne
Upstate,NewYork
My neighborhood, like @Sagebrush is in deep woods, i have Bears, fox, coyotees, bobcats, moose and many other thieaves lol….take your favorite Team Ballcap and toss it over the speaker…now if your taco ventures into mall territory maybe its a issue, i use amazon , not malls , And if all else fails make sure you have insurance that will cover the loss
astroboy
Southern California
Toyota already makes one for lower end trucks...
55474-AK010
what webshot said:
I did not even know that this was thing! I have been driving around without any cover on the speaker slot. Before we know it, someone will come up with a drop in speaker without a rechargeable battery on it.
Josh256
Toronto, ON
2025 Tacoma TRD Pro
It's worth noting you have to remove the dock to install this cover.. 4x 10mm bolts. That said you could easily cut the tabs on this and use some 3M hook+loop tape [velcro] to secure it over the dock *however* you would also have to remove the dock trim/cover piece first -- you can yank it off by hand, pry tool not necessary:
https://www.tacoma4g.com/forum/threads/jbl-replacement-center-channel-speaker-prototype-diy.10601/
astroboy
Southern California
2024 Tacoma Removable JBL center channel speaker. hsd
I thought it was a plug and play cover. Nvm, back to waiting for an actual cover for the speaker slot. That or a speaker that you canm put in there that does not need have a battery on it.
I am tempted to take the route that you took. But I know crap when it comes to a car's electrical system.
Josh256
Toronto, ON
2025 Tacoma TRD Pro
This doesn't exist.. If you have an iPhone with the Lidar sensor you could 3D scan the dock, 3D scan the non-JBL cover, modify into a custom cover design and 3D print ABS or ASA... doubt anyone will be doing that though.. most folks will pull the dock and use the OEM cover I suspect.
