I have not removed mine yet to play with it. It can only be paired with the truck's system? I assumed you could pair it with any Bluetooth source.
Unfortunately I donāt believe it can be. Iāve had my ā24 Tacoma for a little over a month and 5,200 miles and still have not found a way to connect to the vehicle when removedā¦Iām also curious if the radio can be played through the speaker when it is disconnected. I enjoy going to the drive in and think it would be a neat feature to have in the truck bed with the wife and I chilling watching the movies.
I am also waiting for someone to come up with something similar to that.Anyone make a 3D Printable filler for gaping hole in the dash? For those who chose not to leave/user the speaker in the truck?
Toyota already makes one for lower end trucks...Anyone make a 3D Printable filler for gaping hole in the dash? For those who chose not to leave/user the speaker in the truck?
what webshot said:Toyota already makes one for lower end trucks...
55474-AK010
55474-AK010
what webshot said:
It's worth noting you have to remove the dock to install this cover.. 4x 10mm bolts. That said you could easily cut the tabs on this and use some 3M hook+loop tape [velcro] to secure it over the dock *however* you would also have to remove the dock trim/cover piece first -- you can yank it off by hand, pry tool not necessary:I did not even know that this was thing! I have been driving around without any cover on the speaker slot. Before we know it, someone will come up with a drop in speaker without a rechargeable battery on it.
https://www.tacoma4g.com/forum/threads/jbl-replacement-center-channel-speaker-prototype-diy.10601/
This doesn't exist.. If you have an iPhone with the Lidar sensor you could 3D scan the dock, 3D scan the non-JBL cover, modify into a custom cover design and 3D print ABS or ASA... doubt anyone will be doing that though.. most folks will pull the dock and use the OEM cover I suspect.![]()
I thought it was a plug and play cover. Nvm, back to waiting for an actual cover for the speaker slot. That or a speaker that you canm put in there that does not need have a battery on it.
I am tempted to take the route that you took. But I know crap when it comes to a car's electrical system.
