Beat Sonic, need feedback
I've also seen a few connectors in the Tacoma look like they're seated but have another 1/16 of an inch to go before they're really fully seated.
First off, your suggestion on taking out the removable speaker was a good one, it made finding a place for the amp a lot easier.
For a sanity check I attached a picture of the back of my HU before I removed any connectors. I am basically removing the two connectors on the bottom left in that picture, right? That would be the black 10-pin connector and the gray 28-pin connector next to it. If those are not right, then that could be my problem.
All of the Toyota plugs snap securely into the HU. The 10-pin and 28-pin BS plugs snap securely into the HU also. The Toyota 10-pin connector snaps cleanly into the BS cable. But the Toyota 28-pin connector does not snap into the BS cable. I pushed that really hard and it appears to be seated, but it never clicks. Maybe that is the problem?
Thanks for the help. I have done complete sound system installs on several cars and trucks, swapped out ECUs and other components and I did not expect this easy upgrade to be a problem.
2024 Tacoma Beat Sonic, need feedback JBL Wirin
hogshooter
Corey
Plant City, FL
2024 Tacoma Limited 4x4
@TacoFreak There's a few videos on Youtube, I followed this one
Like you I kinda of messed up the first time, and had to watch the video a couple of times to get it right. Like I said earlier the BS connectors are not color coded. White BS to grey Toyota for example.
here's another video:
@hogshooter Yeah I watched those - Thanks!
I'm pretty sure the BS connectors are in the right place. My main question is that Toyota male 28-pin not snapping securely into the BS 28-pin female connector. I might try some mechanical pressure to get them to snap together.
I just have to give it another go when I want to feel stupid again. :)
@hogshooter I watched those videos again, and I did have all of the connectors in the right place. I assume that the problem came from not getting the Toyota 28-pin connector fully seated in the BS wiring harness.
I will give that another try when I get the time, and thanks for the help.
Ron
Vancouver Island
Inspect those connectors - you may have a bent pin or something else blocking it.
Ron
Vancouver Island
I got my BS from @MERAKIAUTOWORKS
Easy process - he was fast to ship it.
I was charged brokerage($10) and taxes across the border but no duties. That might change with a trade war.
Ron
Vancouver Island
The sound is much better than before - with the BS installed - but it does not fix the JBL system. It still sounds like everything is coming from the front center speaker. Attempts to fade the sound to the back reduce overall quality.
Maybe thats why @webshot recommends the rear door speaker upgrade?
The sub in the rear is louder and sounds ok. The front door speakers are louder but still sound like a fart in a beer can.
Overall it sounds much better and i can listen to music. Without the BS, I just turned the JBL off and enjoyed the silence.
webshot
Northern California
The stock rear speakers are terrible in my opinion.
If you go the route of replacing the rear speakers please see my separate write up on this forum! I have found that "Metra" and other brand speaker wire adapters are wired in reverse to the new 2024 Tacoma connectors. Check your polarity!
Also do not over adjust the gain on the BeatSonic amp. It causes odd distortion and static with the front speakers.
I had some time this afternoon to finish my amp install. Thanks for the ideas and help @hogshooter and @Ron.
I did have a couple of bent pins in that 28-pin connector in the Beat Sonic harness, as Ron guessed. :thumbsup: So the harder I tried to make those connectors click together, the worse I made it. I straightened the pins and it snapped together easily and I was back in business.
A couple of quick impressions. Although that amp did not magically turn it into a true premium sound system, it definitely improved the sound. The vocals are more distinct and the mids are not so muddy, and it is now a lot more acceptable. I will probably do a big upgrade in the future, but I can live with it for now.
Now for something strange. My wife and I both thought that the amp improved the sound field, which makes no sense to me. The sound in front is now better distributed and no longer sounds like it is coming only from the removable speaker. I recentered the fad to the factory setting and I think it sounds better than balanced toward the rear, like I had it. The front pillar tweeters have joined the party finally and the sound is much better IMO.
I might upgrade those rear door speakers, which are pretty lame. I need to check your write-up on that @webshot, and that will probably be all I do for now.
Thanks for the input everyone. I do recommend the Beat Sonic amp if you are disappointed with the factory JBL like I was.
Ron
Vancouver Island
I've had some more time with it and now have the fade 2 notches to the back and the center speaker removed.
This stereo is not easy to adjust but the beat sonic might be enough for me long term.
I don't need it loud but its hard to go down in quality from my previous truck that had stock harman kardon.
Understandable. A Harman Kardon sound system is far superior to this JBL in my experience. All automakers now offer premium sound systems, but many of them are not all that great.
