- First Name
- James
- Joined
- May 23, 2024
- Threads
- 2
- Messages
- 1,382
- Reaction score
- 1,552
- Location
- Crozet, Virginia
- Vehicle(s)
- 2024 Tacoma TRD Pro, 2023 Lexus RZ450e
First off, your suggestion on taking out the removable speaker was a good one, it made finding a place for the amp a lot easier.I've also seen a few connectors in the Tacoma look like they're seated but have another 1/16 of an inch to go before they're really fully seated.
For a sanity check I attached a picture of the back of my HU before I removed any connectors. I am basically removing the two connectors on the bottom left in that picture, right? That would be the black 10-pin connector and the gray 28-pin connector next to it. If those are not right, then that could be my problem.
All of the Toyota plugs snap securely into the HU. The 10-pin and 28-pin BS plugs snap securely into the HU also. The Toyota 10-pin connector snaps cleanly into the BS cable. But the Toyota 28-pin connector does not snap into the BS cable. I pushed that really hard and it appears to be seated, but it never clicks. Maybe that is the problem?
Thanks for the help. I have done complete sound system installs on several cars and trucks, swapped out ECUs and other components and I did not expect this easy upgrade to be a problem.
