JustDSM
Justin
Ogden, UT
2024 Tacoma TRD Offroad
At Overland Tailor Tuning (OTT), we're committed to delivering cutting-edge solutions and accurate information for your Toyota tuning needs. During our research and development—along with valuable feedback from the community/customers—we’ve uncovered a critical issue that 4th Gen Tacoma owners interested in fitting the TRD intake to their non-Pro or Trail Hunter:
TRD Pro and Trail Hunter Intake Systems are NOT plug-and-play with standard Tacoma models, including non-Pro and Trail Hunter hybrid models.
While these upgraded intake systems are popular for their performance and rugged design, they cannot be retrofitted to non-TRD Pro, Trail Hunter, or hybrid Tacomas without custom calibration. Here’s why:
  • Physical Differences in Airboxes & MAF Housing: The internal geometry of the airbox and MAF sensor housing in these systems is significantly different from stock Tacoma configurations.
  • Calibration Required: These differences disrupt the MAF sensor’s ability to correctly measure airflow, resulting in fueling errors, poor performance, and triggering the dreaded Check Engine Light (CEL).
What This Means for You
If you’ve installed—or plan to install—a TRD Pro or Trail Hunter intake system on your 4th Gen Tacoma, a custom calibration is essential to avoid:
  • Incorrect air-fuel ratios
  • Performance degradation
  • Potential long-term engine damage
OTT’s Upcoming Solution
At OTT, we specialize in creating custom calibration solutions for Toyota vehicles. We are excited to announce that not long after the release of the 4th Gen Tacoma tune, we plan to offer MAF calibration services specifically for this swap. These calibrations will ensure seamless compatibility between TRD Pro and Trail Hunter intake systems and standard 4th Gen Tacomas, including non-Pro and hybrid models.
Stay tuned for more updates as we continue to refine and expand our offerings to meet the needs of the 4th Gen Tacoma community. The release is not far away!
JustDSM
JustDSM
Justin
Ogden, UT
As promised, we have an update for you with developments on this topic.
We have successfully reworked the MAF calibration for the TRD Pro & Trail Hunter airbox to allow use and retrofitting on non-Pro & Trail Hunter models.
We're pleased to announce that we'll be able to offer calibration support for the TRD Pro & Traill Hunter Airbox retrofit at our initial product launch.
AZTaco
AZ
Toyota
Well the million dollar question is, if the Pro/TH intakes throw codes in non Pro/TH Tacomas because they flow more, then how does the hp/tq curves differ when recalibrated?
Toyota doesn't show a hp/tq gain for the Pro (but does show a decrease for the TH - snorkel more restrictive?). Is there more power under the curve?
JustDSM
JustDSM
Justin
Ogden, UT
We've gathered the calibration data for the Pro/Trail Hunter (TH) airbox and will be putting it on the dyno soon to provide performance data.
One important takeaway is that the Pro/Trail Hunter airbox has a higher airflow ceiling before the MAF sensor reaches its limit. This means it can measure a greater mass of air over time, thanks to a larger metering section in the housing compared to the standard airbox.
Since the Pro/TH airbox includes a separate fender duct (which can be capped on the Pro), it's reasonable to assume it offers greater overall airflow capacity than the standard intake. While we haven’t specifically tested restriction levels yet, the Pro/TH airbox is likely less restrictive than the factory airbox.
Why This Intake Triggers a CEL on Non-Pro/TH Tacomas
The Check Engine Light (CEL) isn’t caused by the higher airflow alone—it’s due to how the ECU processes that airflow. The Pro/TH MAF housing is physically larger, which means the same MAF sensor frequency now corresponds to a different mass of incoming air than the ECU expects to see.
Because the stock ECU is calibrated for the standard airbox, swapping to the Pro/TH intake without adjusting the MAF calibration causes incorrect airflow readings and fueling calculations. The ECU attempts to correct the error with fuel trims, but it triggers a CEL when the deviation exceeds the allowable threshold.
Solution: Proper MAF Calibration
Custom MAF calibration is required to use the Pro/TH airbox on a non-Pro/TH Tacoma without issues. Updating the ECU’s airflow tables ensures it correctly interprets the new housing’s readings, restoring proper fueling and preventing CELs.
Upcoming Testing
Along with dyno testing the Pro/TH airbox, we’ll also be testing it against another aftermarket intake specifically designed for non-Pro/TH models. This will give us a better comparison of airflow characteristics, performance gains, and how each intake interacts with proper MAF calibration.
With the calibration data in hand, we'll be sharing results soon!
