WCS (Wireless Camera System) for 4G Tacoma
viviwill
will
2024 Tacoma OR
Any updates on this, guys?
Lennyz1
Len
NY
I found one and ordered it.. I’ll let you guys know how well it works.. If nothing else, at least I have the camera part of the system..
Any update on your findings? Did it work?
Bcphoto3
Bill
Oak Ridge, TN
No because what was described as the camera system was just a power adapter. Found the system for about $900 from dealer but don’t want to buy that until know it will work and whether dealers can potentially install the other 2 fins. Seems like dealers have no idea and trying to talk to Toyota engineers is like talking to the wall. The response I got from them at Overland East about the small gas tank was frivolous. They have no idea what the real mpg is nor the range. They probably all drive a Prius and small gas tank is NBD. End of rant!
Lennyz1
Len
NY
Tks for the update, but that sucks. Let us know if you find anything else out.
Do you have the PN for the camera?
@Gurvy522 if you still want to play around, here's where you can look for the trailer ECU (pulled from service manual):
Last Modified: 04-03-2024​
6.11:8.1.0 Doc ID: RM100000002K7ZY
Model Year Start: 2024​
Model: Tacoma​
Prod Date Range: [03/2024 - ]​
Title: MIRROR (INT): TRAILER CAMERA ECU: INSTALLATION; 2024 MY Tacoma Tacoma HV [03/2024 - ]​
INSTALLATION
CAUTION / NOTICE / HINT
HINT:
A bolt without a torque specification is shown in the standard bolt chart.
Click here
COMPONENTS (INSTALLATION)
Procedure​
Part Name Code​
1​
COMMUNICATION TELEMATICS BOX​
867E1​
2​
NO. 1 BACK PANEL SILENCER​
64141H​
3​
NO. 3 SPEAKER WITH BOX ASSEMBLY​
86150C​
4​
REAR CENTER OUTER SEAT BELT ASSEMBLY​
73350C​
*A​
for 10 Speakers​
*B​
Silencer type A​
*C​
Silencer type B​
Tightening torque for "Major areas involving basic vehicle performance such as moving/turning/stopping": N*m (kgf*cm, ft.*lbf)​
N*m (kgf*cm, ft.*lbf): Specified torque​
Procedure​
Part Name Code​
5​
SEAT FLOOR BOX​
58635B​
6​
UPPER LUGGAGE COMPARTMENT GARNISH​
64712G​
7​
REAR LUGGAGE COMPARTMENT TRIM COVER SUB-ASSEMBLY​
64706B​
8​
LUGGAGE COMPARTMENT BOX RH​
64429E​
9​
LUGGAGE COMPARTMENT BOX LH​
64439D​
10​
PACKAGE TRAY TRIM STRAP​
64367B​
11​
REAR UNDER SIDE COVER RH​
76973H​
12​
REAR UNDER SIDE COVER LH​
76974J​
13​
REAR DOOR SCUFF PLATE RH​
67917C​
14​
REAR DOOR SCUFF PLATE LH​
67918E​
15​
REAR SEAT ASSEMBLY RH​
16​
REAR SEAT ASSEMBLY LH​
17​
CONNECT CABLE TO NEGATIVE AUXILIARY BATTERY TERMINAL​
18​
REGISTRATION​
*A​
w/ LUGGAGE COMPARTMENT BOX​
*B​
w/o LUGGAGE COMPARTMENT BOX​
*a​
The illustrations are representative examples, and details may differ.​
PROCEDURE
1. INSTALL COMMUNICATION TELEMATICS BOX
Nut​
Connector​
(1) Install the communication telematics box with the 3 nuts in the order shown in the illustration.
Torque:
12.3 N·m {125 kgf·cm, 9 ft·lbf}
(2) Connect the connector.
2. INSTALL NO. 1 BACK PANEL SILENCER
Click here
3. INSTALL NO. 3 SPEAKER WITH BOX ASSEMBLY (for 10 Speakers)
Click here
4. INSTALL REAR CENTER OUTER SEAT BELT ASSEMBLY
Click here
5. INSTALL SEAT FLOOR BOX (w/o LUGGAGE COMPARTMENT BOX)
6. INSTALL UPPER LUGGAGE COMPARTMENT GARNISH (w/o LUGGAGE COMPARTMENT BOX)
7. INSTALL REAR LUGGAGE COMPARTMENT TRIM COVER SUB-ASSEMBLY (w/o LUGGAGE COMPARTMENT BOX)
8. INSTALL LUGGAGE COMPARTMENT BOX RH (w/ LUGGAGE COMPARTMENT BOX)
9. INSTALL LUGGAGE COMPARTMENT BOX LH (w/ LUGGAGE COMPARTMENT BOX)
10. INSTALL PACKAGE TRAY TRIM STRAP
11. INSTALL REAR UNDER SIDE COVER RH
12. INSTALL REAR UNDER SIDE COVER LH
13. INSTALL REAR DOOR SCUFF PLATE RH
14. INSTALL REAR DOOR SCUFF PLATE LH
15. INSTALL REAR SEAT ASSEMBLY RH
Click here
16. INSTALL REAR SEAT ASSEMBLY LH
Click here
17. CONNECT CABLE TO NEGATIVE AUXILIARY BATTERY TERMINAL
  • for Gasoline Model:
    Click here
  • except Gasoline Model:
    Click here
18. REGISTRATION
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006552280-xt
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006552382-qf
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006552486-nh
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006552573-yn
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006553103-ws
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006553206-v5
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006553299-gz
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006553374-xh
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006553434-ju
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006553517-24
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006553745-57
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006553841-h8
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006553924-sm
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006554008-lq
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006554158-is
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740006554314-jz
Lennyz1
Len
NY
?? Just need this box? No antenna? I found price around $400 for Telematics box. I am assuming the rest of the speaker box and seat belt assy is not needed.
Thanks, Interesting info.
Gurvy522
Gurvy522
Chicago, IL
Antennas would still be needed. Not sure about whether associated wiring harness is already in the truck as well.
Curious as to where you found the telematics box (and associated full part number)? I was having a rough time finding it.
bought a copy of the factory service manual.
and supporting your statements that the antennas and wiring are separate. It has those diagrams as well.
Some fun additionals for you Gurvy (if you confirm the module is behind the seat and buy a camera) - here are the troubleshooting steps for seeing the camera
Wireless camera image is not displayed when the AUX menu icon is pressed.
Confirm that 12 V power is being supplied to the wireless camera or that the internal battery is more than 30 % charged​
Confirm that the wireless camera is paired with the trailer camera ECU (communication telematics box)​
Confirm that the audio and visual system is operating correctly.​
Confirm that the panoramic view monitor system is operating correctly.​
Proceed to "Trailer Camera Image is not Displayed or Blinking Intermittently"​
Title: MIRROR (INT): TRAILER CAMERA SYSTEM: Trailer Camera Image is not Displayed or Blinking Intermittently; 2024 MY Tacoma Tacoma HV [12/2023 - ]​
Trailer Camera Image is not Displayed or Blinking Intermittently​
DESCRIPTION
The display signal from the wireless camera is transmitted to the display.
WIRING DIAGRAM
HINT:
  • Perform pairing after replacing or removing and installing the wireless camera.
    Click here
  • Inspect the fuse for circuits related to this system before performing the following procedure.
  • Inner rear view mirror may flicker if wireless connection is poor. Due to inherit wireless limitation (out of performance range or scope) .
PROCEDURE
1.​
CHECK TRAILER CAMERA SYSTEM (CURRENT SIGNAL STRENGTH)
(a) Ensure the trailer camera system is tested without obstacles blocking line of sight or strong nearby Wi-Fi interference.
(b) Navigate to AUX menu screen on the multi-display and enter the diagnostic menu.
(c) Locate wireless signal strength menu parameter and take note of current signal strength when camera is 914.5 cm (30.00 ft.) behind the rear of the vehicle.
(d) Check the flicker condition is present when the wireless camera is 30 feet behind rear of vehicle.
OK:
Flicker does not occurs.
OK
END (TRAILER CAMERA SYSTEM IS WORKING WITHIN THE DESIGNED PERFORMANCE SCOPE)
NG​
2.​
(a) Bring the wireless camera closer to vehicle rear until flickering stops or signal strength improves.
(b) Move back away from vehicle rear until flicker or signal strength is equal to the original recorded value.
(c) Check the distance from the telephone antenna assembly is 914.5 cm (30.00 ft.) or more.
OK:
The distance from the telephone antenna is 914.5 cm (30.00 ft.) or more.
OK
NG​
3.​
CHECK WIRELESS CAMERA
(a) Check the wireless camera antenna and connector for visual damage.
Result​
Proceed to​
Damage is present​
A​
Damage is not present​
B​
A
REPLACE WIRELESS CAMERA
B​
4.​
CHECK HARNESS AND CONNECTOR (TRAILER CAMERA ECU - BATTERY AND BODY GROUND)
(a) Disconnect the R14 trailer camera ECU connector.
(b) Measure the resistance according to the value(s) in the table below.
Standard Resistance:
Click Location & Routing(R14)
Click Connector(R14)
Tester Connection​
Condition​
Specified Condition​
R14-4 (GND) - Body ground​
Always​
Below 1 Ω​
(c) Measure the voltage according to the value(s) in the table below.
Standard Voltage:
Tester Connection​
Switch Condition​
R14-1 (ECUB) - R14-4 (GND)​
Ignition switch off​
11 to 14 V​
R14-2 (ACC) - R14-4 (GND)​
Ignition switch ACC​
11 to 14 V​
Below 1 V​
NG
REPAIR OR REPLACE HARNESS OR CONNECTOR
OK​
5.​
CHECK HARNESS AND CONNECTOR (TRAILER CAMERA ECU - PARKING ASSIST ECU)
(a) Disconnect the R37 parking assist ECU connector.
(b) Disconnect the R38 trailer camera ECU connector.
(c) Measure the resistance according to the value(s) in the table below.
Click Location & Routing(R37,R38)
Click Connector(R37)
Click Connector(R38)
Tester Connection​
Condition​
R37-2 (XCB+) - R38-2 (XCB+)​
Always​
Below 1 Ω​
R37-3 (XCV+) - R38-3 (XCV+)​
Always​
Below 1 Ω​
R37-4 (XCV-) - R38-4 (XCV-)​
Always​
Below 1 Ω​
R37-1 (XGND) - R38-1 (XGND)​
Always​
Below 1 Ω​
R37-5 (XCSD) - R38-5 (XCSD)​
Always​
Below 1 Ω​
R37-2 (XCB+) or R38-2 (XCB+) - Body ground​
Always​
10 kΩ or higher​
R37-3 (XCV+) or R38-3 (XCV+) - Body ground​
Always​
10 kΩ or higher​
R37-4 (XCV-) or R38-4 (XCV-) - Body ground​
Always​
10 kΩ or higher​
R37-1 (XGND) or R38-1 (XGND) - Body ground​
Always​
10 kΩ or higher​
R37-5 (XCSD) or R38-5 (XCSD) - Body ground​
Always​
10 kΩ or higher​
NG
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740069655312-y6
Title: MIRROR (INT): TRAILER CAMERA ANTENNA: REMOVAL; 2024 MY Tacoma Tacoma HV [12/2023 - ]​
REMOVAL
HINT:
  • Use the same procedure for the RH and LH sides.
  • The procedure listed below is for the LH side.
COMPONENTS (REMOVAL)
Procedure​
Part Name Code​
1​
ROOF HEADLINING ASSEMBLY​
Procedure​
Part Name Code​
2​
TELEPHONE ANTENNA ASSEMBLY​
86760​
*1​
ROOF ANTENNA HOUSING​
â—Ź​
Non-reusable part​
PROCEDURE
1. REMOVE ROOF HEADLINING ASSEMBLY
Click here
2. REMOVE TELEPHONE ANTENNA ASSEMBLY
Remove in this Direction (1)​
Remove in this Direction (2)​
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740069919514-yr
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740069919627-9k
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740069919781-8
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740069919805-ge
2024 Tacoma WCS (Wireless Camera System) for 4G Tacoma 1740069919828-3
Lennyz1
Len
NY
Found a couple different ones. All about the same price. Tried to narrow down using search with specific vehicle and no luck.
Only one antenna I see? I thought it added 2? I am seeing about $300 for the antenna.
These were identified earlier in the thread:
Left Hand Telephone Assembly Antenna - PT887-0C137-LH
Right Hand Telephone Assembly Antenna - PT887-0C121-RH
Lennyz1
Len
NY
TKS, been a long time since reading this thread.
