I have a Limited so my OEM grill may be different than yours. I am planning on using the 3d printed file that Gurvy522 uploaded, which I assume is near identical to the Rave bracket. Do I need tech stream or is all this adjusting able to be done by me in the infotainment?Yes. Park where there are lines so you can check alignment.
Also, you previously mention you only can save once. What happens after that? How do you do it again if you ever need to?
