Brake controller harness for 4th gen Tacoma?
d27bessette
2016 Highlander Limited, 2015 Rav4 XLE, 2022 Tundr
Well I just hit a wall today. was going to install a brake controller on a friend's Taco and notice they don't have any plug for it like the last gen did. Not listed anywhere also... Anybody here had one installed or do I have to do it wire by wire?
Gear_yyc
Unfortunately, the manual says Toyota doesn't recommend the use of a third party trailer brake controller with this truck. That's quite frustrating, as other OEMs that offer factory-installed brake controllers also have provisions for aftermarket controllers.
bking
Bernie
2024 Tacoma TRD Offroad
If they do that, how are they going to sell upgrade packages :). If you're patient, someone will sell wiring harnesses. Map it out, maybe it will be you!
Lando
Is there a wireless one out now? Works with a remote. I recall I read about one.
M1KL83
Tacoma TRD OR 6MT
I wonder if the 2022-24 Tundra factory brake controller would be plug and play in the new Tacoma?
2024 Tacoma Brake controller harness for 4th gen Tacoma? Screenshot_20240317-180745_Chrome
M1KL83
Tacoma TRD OR 6MT
Did you look under the driver's side kick panel? If memory serves, I read on the Tundra forum that's where they found the pigtail on new gens that didn't come with brake controller from factory.
It will be very unfortunate if it's not hidden in there somewhere as I'm sure adding a brake controller to the base Offroad/SR5/SR will be a common addition for owners that didn't receive one from factory.
Redarc's are fantastic however oem has its benefits.
d27bessette
This won't work, the harness for it is not even there, it also need the brake controller ECU which is also missing, the whole harness is different so we cannot even buy the ecu and plug it
M1KL83
Tacoma TRD OR 6MT
Did you end up finding the wire or figure a fix?
Windsor
Ontario canada
I'm in the same boat with my 2024 tacoma . The Dealership said there is a plug there for sure . If it is I have no idea where . ---Never trust a salesman . Has anybody had any luck plugging in an aftermarket brake controller ? ---I cant believe that they would sell a truck to tow 6400 pounds with no provision for braking .
M1KL83
Tacoma TRD OR 6MT
I'm pushing my local dealership to figure out where the heck this plug is but so far no luck please update if you're the first find it!
JBSwine
2022 Kia Sorento
Look under the dash for something like this:
2024 Tacoma Brake controller harness for 4th gen Tacoma? Screenshot 2024-04-16 095835
