- Joined
- Feb 10, 2024
- Threads
- 7
- Messages
- 70
- Reaction score
- 31
- Location
- Pittsburgh
- Vehicle(s)
- Subaru Outback
I am the proud owner of a new Offroad shortbed. The truck is great however something I didn't notice on the test drive or in my time fiddling with it before buying was a slight whistling sound in the HVAC. Wondering if anyone else has noticed this. I saw on the tundra forum and toyota forums in general others have noted similar issue. I've narrowed down the settings to reproduce. I am hoping with some time of it breaking in that it may go away.
1. Fan settings in the middle range notch 3/4/5
2. Vents on upper only
3. Air conditioning or auto-climate on
I notice the sound appear around notch 3 fan speed and go away when I go to max fan speed. It is a high pitched but not loud noise and it is a whistling sound. It goes away immediately when the AC is switched off or if I switch AC to max as max setting does something with with moving the flaps internally. Its warm here so I haven't tested it with heat on. The noise isn't present when using any other setting...just top vents only. I have also tried opening/closing vents and it doesn't seem to resolve it completely.
Figured i'd start a thread. I'll take it to the dealer after a bit if it doesn't improve. I've only had it one day so might just be breaking in stuff. After a bit of fiddling changing the settings... going to ac on/off and to max etc I noticed it go away but I expect it will come back.
