theKurt
- First Name
- Kurtis
- Joined
- Apr 5, 2024
- Threads
- 10
- Messages
- 61
- Reaction score
- 82
- Location
- Calgary, Canada
- Vehicle(s)
- 2024 Tacoma Sport+ 6M
Since most manufacturers use common wiring harnesses across their lineup, I went hunting for unused connectors in my Sport+.
In the front right fuse box under the hood, I found a spot for the inverter relay. I don’t have an inverter, so my plug was empty. However, peering through the hole next to it there was a bundle of white and black wires that appear to be of sufficient gauge to power an inverter, but they are not connected to anything. Just wrapped together. I will investigate further.
In the front left fuse box, I found a 50A fuse that was labelled “TIRE INFL”. After some searching, I have found no explanation. I am a little bit hopeful it is for the tire inflator that might come with higher end models. I will see if I can find a corresponding connector somewhere. Not sure if there is something behind the drivers console for a switch
Behind the right rear seat is a connector that goes nowhere. It has several large wires. Might be useful. I will investigate further.
Possibly some unused connectors under the right rear seat. A blue one caught my eye. Not sure what it’s for.
Another black connector near the rear bumper. Not the Aux connector that has been discussed. Another one. Not sure what the deal is there.
I’m still going to keep looking for more. I’d love to get a wiring diagram for this truck.
Anyone else found some possible points to add undelivered options or possibly places to obtain power for other gadgets? I’m sure there are goodies under the steering wheel area and possibly tucked in behind the taillights.
