Just pickup a KO3 @tirerack this week now I’m Looking for after market Wheels but I notice almost 90% are using Method Wheels what is so special in Method wheels in compare to other BRAND.
I put Method 705's on my truck. I don't think there's anything special about Methods but I like how most of their options are clean, simple designs. They look good in an understated kind of way.Just pickup a KO3 @tirerack this week now I’m Looking for after market Wheels but I notice almost 90% are using Method Wheels what is so special in Method wheels in compare to other BRAND.
Im thinking it should fit the 24TacomaDo you know offhand the specs on the Tundra wheels?
Dia:
Offset:
Hub dia:
And off set?Off road 17″ diameter, 7.5″ width
+55And off set?
Do you know if the 18" sport wheel is 7.5 wide and has an offset of 55 too?
With lots of poke. Rim will stick out 59 mm farther.Im thinking it should fit the 24Tacoma
Wheel Size: 18x9.0J -Bolt Pattern: 6x139.7 -Offset: +15 -Bore: 95.1mm -Finish: Matt Black.
Personally like Method wheels due to their Bead Grip technology for those that don't want to deal with beadlocks (me). Definitely can't air down to 0 psi like beadlocks but airing down 8-10 psi without popping the bead is pretty easy for the bead grips based on my experience.Just pickup a KO3 @tirerack this week now I’m Looking for after market Wheels but I notice almost 90% are using Method Wheels what is so special in Method wheels in compare to other BRAND.
