TPMS won’t stay on gauge cluster
GMak621
George
Nørțh Çøast
24 Tacoma TRD ØR
Hello all. Just picked up my 24 TRD OR a few days ago.
I love the truck so far coming from a 21 Tacoma. Better in every aspect.
One thing that has been an issue is I want TPMS on one of the three gauge cluster options and it seems to be reverting back to trip info once truck is turned off and back on.
Have to hold OK on left side of steering wheel and change it back every time. The other two gauge options are staying put.
When truck starts it’s always boost gauge and mpg. Which is fine. But the TPMS gauge keeps reverting to trip info…
GMak621
GMak621
George
Nørțh Çøast
24 Tacoma TRD ØR
TPMS will not hold. Mine does the same thing and after a bit of research discovered that it is a software issue with Toyota and not limited to the 2024 Tacomas.
Dang it. Oh well not super crucial. Appreciate the response
2024 TRD Sport-Bronze oxide
Maybe because tire pressure is not going to fluctuate very much so no need to have it constantly showing. I'm sure you get an alert if one loses pressure, though.
Kdbradley85
2024 Toyota Tacoma TRD OR MT
Same problem here. I’ve noticed though, because it’s not always reverting, that when it does revert to the trip meter, if I put the electronic parking brake on, it’ll switch back to the tpms screen. It’s definitely a software glitch. I use Apple CarPlay too, and sometimes it’ll kick back to the factory GPS map screen even though the phone is still connected, and this will tend to happen right when I stop and put the brake on.
Code3TRD
Arman
LA / PHX
24 Tacoma TRD OR Premium
Same problem here. Not super critical but it’s annoying…
Well, thanks to this thread I now know the reason why it doesn't stay on the dash.
Porsche
Honolulu
I noticed when I start my truck up and wait a few seconds before I put it in gear whatever screen u selected it will revert back to that screen (TPMS) you have selected.
MNTBKR
Luis
Central, FL
Following, because I had also noticed this behavior. Wonder if we should be reporting this to Toyota?
Kdbradley85
This. Most of the time, if I just wait a couple seconds before releasing the parking brake, it reverts back to the TPMS display. If I release the parking brake before this happens, it will stay on the trip meter display until I stop and put the parking brake back on, and then it will switch back to the TPMS display. It's weird that it does this, but not really that big of a deal. I like my tach on the left with the turbo gauge, digital speed in the middle with the cruise setting under it, and the "analog" speedometer on the right with the tire pressure display. I drive a lot on job sites and if I catch a screw or nail in one of my tires, I want to know about it ASAP!
goin2drt
KY
2-3 other threads on this in other forums. It is not staying for anyone like all the other displays remain. For most it reverts back to Trip B.
UT
It's a software bug/glitch/issue. Not sure why people aren't understanding that lol. Highly doubt it will ever be fixed as it is persistent on other Toyota models as well. Just have to live with it and change it back when you want to look at the pressure readings.
Dansflhti
Nova Scotia
I understand it is a software glitch...What I don't understand is why Toyota does not fix the glitch?
