Not sure if it's the same or not. I've seen some pics where it looks like the 14" has a larger volume knob that is actually in the center of the dash above the AC controls compared to the knob in the side of the 8".Iāve see it done on the tundra. Should be an easy plug and play swap.
I think it would take a change of the HVAC controls, since the volume knob is between the air vents. I also think they may be scarce since I tried to find a dealer with an OR Upgrade package + the 14" screen and it's not happening.Should be an easy plug and play swap
Damn. I didnāt think about the volume knob. Im probably stuck with myI think it would take a change of the HVAC controls, since the volume knob is between the air vents. I also think they may be scarce since I tried to find a dealer with an OR Upgrade package + the 14" screen and it's not happening.
I rarely use the knob anyhow.. Volume controls on the steering wheel.Damn. I didnāt think about the volume knob. Im probably stuck with my
8 inch. Was looking to upgrade after seeing the 14inch display at the dealer. Sooo nice.
