Administrator
Administrator
Staff member
Tacoma4G.com
www.tacoma4g.com
Toyota
Official description of the TRD Pro FOX suspension:
TRD Pro comes fitted with TRD-tuned FOX® QS3 three-way adjustable internal bypass shocks with remote reservoirs for improved high speed off-road performance and external FOX Internal Floating Piston (IFP) rear bump stops to improve bottom out feel.
TRD Pro features TRD-tuned FOX® QS3 internal bypass shocks with 2.5-inch aluminum housings and rear remote reservoirs. Quick Switch 3 (QS3) technology allows for manual adjustment of compression damping on each shock to match the terrain.
ReddingonTRD
Sean
Orange County
Hi! Are there any instructions on how to adjust in the manual? I can’t seem to find any procedure…
WhiteLightning
Noah
Perrysburg, OH
2023 Toyota Tacoma Off-Road
If you mean to adjust the shocks? Each shock has a switch with 3 levels of adjustment behind the wheel. You will see the switch located there. I believe 1 is firm and 3 is for most articulation.
Wutangz_Taco
Andy
2024 TRD Pro Tacoma
backwards. 1 is soft. 3 is firm. Either way it says softer or firmer with directions to turn the adjustments.
WhiteLightning
Noah
Perrysburg, OH
I knew I had a 50/50 shot lol. I will be getting my pro i assume in about a week, hopefully less. Do you have your shocks set to 1 for everyday driving?
Wutangz_Taco
Andy
2024 TRD Pro Tacoma
I don’t have mine yet, but I’ve watched every video out there. lol. Shoot, I don’t even have a permanent VIN yet!!
ReddingonTRD
Sean
Orange County
Thanks so much for the reply :). After reading your post I crawled underneath. I need to clean off some dirt to confirm what setting is established. Before I turned the switch I thought I should take a gander at instructions or a manual, but I can’t seem to find. Straightforward enough right?
WhiteLightning
Noah
Perrysburg, OH
What color you getting? The 30 day wait from port to get on a boat sucked. It should be off boat right now.
Wutangz_Taco
Andy
2024 TRD Pro Tacoma
I’ve got a white/black one coming in. Mudguards are my only option. Base-level pro, ha ha. What are you getting?
Wutangz_Taco
Andy
2024 TRD Pro Tacoma
Terra Pro, spray bedliner, mudguards, door panel protector stuff, and the usb c cable package
Oh, man. The USB cable package was the one I was searching for. Good work. Ha ha. Sounds like it will be a sweet machine. Wish I had the spray in bedliner. Oh well.
WhiteLightning
Noah
Perrysburg, OH
I wanted to get a hard cover and the dash cam. Ended up finding a really good dashcam on amazon prime day for like $100 off at $299 instead of toyotas $500. At this point i’ll just get a soft bed cover later on. I just wanted the terra paint. Underground was my second choice IF I couldn’t get terra.
@WhiteLightning Terra was my top choice and then later my only choice. Underground was my second choice too, but for me there is no comparison. My truck is the only Pro my dealer has been allocated. It just happened to be Terra and I was first in line.
Wow - 30 days to get on a boat. Mine has been built for almost two weeks so I have a way to go. How long did it take for your status to go from build phase to transport? Mine has shown build phase since it got a permanent VIN and hit the inventory search.
Since mine will be a while I would love to see some pictures of yours when you get it! I may be biased but a Terra Pro is the best looking truck I have ever seen. :cool:
And sorry about the thread jack - that video is cool. I am just losing my mind waiting for my new truck to find its way to me.
WhiteLightning
Noah
Perrysburg, OH
It was built on 6/26, processed and got to port on 6/28. Then I kinda got a little impatient and tracked vehicle carrier boats that were gonna go to the port I knew it was going to lol. Long 30 days…
Tom Sellick
Ontario
2024 TRD Pro
As some have said...no description in the manual. I'm assuming this is currently set to 3 the softest setting? And for road it should be on 1?
Kind of depends if the short or long side of the switch is the pointer..:)
2024 Tacoma Close-up look at 2024 Tacoma TRD Pro FOX Suspension at work IMG_5068
