2024 TRD Off Road Suspension - harsh / issue?
RFish
2024 Tacoma TRD off road (soon)
Do guys feel like your front suspension either bottoms out real fast/easy/maybe too harsh with no bump stomp or either rebounds to fast and sorta "clunks" at your feet.
Went over everything it all seems tight.
ldudiaz
Lisandro Diaz
Leesport, PA
24 Tacoma RTD Sport
I have the trd sport and I feel every bump there is. I definitely get the clunks. It is my first truck ever so Iā€™m not sure if this a truck feel or the suspension doesnā€™t absorb the bumps real good
Rover Rover
Southern California
Toyota went pretty conservative with the bump stops this time around, Iā€™ve noticed it too. Iā€™m no expert in suspension but you can easily feel it if you find an aggressive speed bump and hit it over 20mph. I also recall a video where one of the YouTubers was beating on their stock TRDOR and managed to damage the bump stop, mind you they couldā€™ve been doing 65 mph on the trail, wasnā€™t sure what happened there. Furthermore, TRDJon also complained about the stock bump stops in a recent post on YT during his Moab trip, but had no issues beyond them just feeling too high.
RFish
Ok so you guys with stock tires even feel this. I thought maybe the bigger 285 k03 were maybe too heavy for these shocks Er something.
bking
Bernie
2024 Tacoma TRD Offroad
I have 10-Ply 33s and I think it rides pretty well. I think I hit a bump stop once when I hit a huge pot hold at 40mph. Nothing you need to worry about.
GMak621
George
NĆørțh ƇĆøast
24 Tacoma TRD ƘR
Yes. I did notice the clunk going over a speed bump. Canā€™t wait for some updated progressive bumps to be available
CuriousTaco
Seattle
TRD OR Base
I noticed the same thing this past weekend with stock tires. The rear bump stops were frequently bottoming out loaded down with RTT and full bed of camping equipment. Wasnā€™t even squatting that badly. Hoping aftermarket options come out soon!
DawnPatrol
Wrightsville Beach
2025 SR5 4x4
The outgoing model had bump stops mounted in the subframe where the current gen has them incorporated into the top hat.
not a great design in my opinion but sure the aftermarket will offer better options in the future .
As far as general ride quality, I appreciate the stiff chassis and tuning for on road usage compared to the wallowy outgoing model
Rocko
Oregon
2024 trd w/upgrade
I am looking forward to an upgraded option from bilstein or Fox so I can eventually replace my stock 2024 trd OR shocks. I will have this truck for 10+ years so upgrading makes sense. Stock is pretty good, but I have had better and it is worth it for me.
Miqie
2024 TRD Sport-Bronze oxide.
Make sure your tires are at 32psi if you have the stock Michelins. Just a couple psi over makes a big difference.
IMAC138
Ian Mac
PNW, Oregon
I just hit my first big speed bumps an hour ago at a decent speed...my TRD OR took the intitial hit really well but as the front suspension went to full extension on the backside of the bumps there was a noticeable clunk when the coil topped out. First thing I thought was 'hmm, that feels different than my '21" and came home to look up if anyone felt this too. Glad I'm not the only one since I instantly got this nervous feeling something was wrong with my new rig.
SnowmanJPS
Halifax, NS
2025 TRD Pro
Where did you manage to find 285 ko3s in canada please?
Frog Mack
Frog
Mississippi
24 Tacoma TRD OR, 14 FJC
Iā€™m glad to hear Iā€™m not alone in this ā€œclunkā€ issue. I wondered if it might be the bump stops. Iā€™ve been driving the same field roads for 25-30 years and the clunk is new with the 24. No clunk in the ā€˜22, the ā€˜14, ā€˜07, or any older ones, except when a front shock was loose, tie rod worn, or steer rack bushings were worn.
