Independence Overland
It worked previously. I went to air up the tires and suddenly the deflate valve was stuck open. So as the compressor is trying to inflate my tires, a valve is apparently stuck open allowing air to dump at the same time.
Right before a weeklong trip of course.
I took out the compressor air filter out to check it even though I was pretty sure that wasn’t it, and it’s not.
This isn’t a known issue, Toyotas guys haven’t seen it before. I’ve got an appointment for the warranty fix but it will be several weeks, and then I’m sure the parts will take a while.
I will post the fix here, and if anyone else does happens to run into this and finds a fix, please post below!
