Color matched exterior door handles - part numbers #?
hogshooter
Corey
Plant City, FL
2024 Tacoma Limited 4x4
Tsturbo
Terry
WA State
‘24 Tacoma Limited
Wanting the same information! Any Toyota parts guys or gals on here who could help?
Tsturbo
Terry
WA State
‘24 Tacoma Limited
Deuce, could you provide the numbers for windchill Pearl? Thanks 👍👍
Just remove the final two digits and search with a wildcard. The last set is the color code.
G0 = dark green (color number 6V7)
E2 = terra (color number 4Z0)
B2 = dark gray (color number 1L7) [Underground?]
B0 = gray metallic? (color number 1G3)
D0 = emotional red (color number 3U5)
A0 = platinum white pearl metallic (color number 089)
E0 = vintage brown pearl (color number 4X4)
G1 = urban khaki (color number 6X3)
G2 = oxide bronze metallic (color number 6X1) [Bronze Oxide]
B1 = silver metallic cs (color number 1J9)
C1 = black (color number 202)
A1 = super white 2 (color number 089)
E1 = pop orange cs (color number 4W5)
C0 = attitude black cs (color number 218)
J1 = dark blue mm (color number 8W7)
J0 = dark blue metallic (color number 8X8)
based on not seeing certain colors in the list (I queried them out based on the Front Door handle, Left Hand (69210-0C100-%)... I suspect there could be a different part number depending on your trim level (touch lock/unlock vs. not).
I wonder if the A0 is the windchill or the super white of A1?
Brady
Midwest
24 Tacoma TRD Sport
HAs anyone found out if there are different part numbers depending on the different models? I have the slim key, want to make sure I don't get something that's not going to work. Also, any good write ups or videos on how to get the color matched part off of the door handle to swap out?
dholmq
Darren
Central Oregon Coast
2024 Tacoma Limited (Celestial Silver)
I would also like any information how to make the swap for my Limited and make sure the key card/remotes won't have issues. Thanks in advance.
dholmq
Darren
Looks like 69211 is the handle outside at $45 and 69210 is the assembly. Im thinking only the outside would be neccesary for a color change. But I do also wonder if there are different handles for models with and without the slim key.
Did you find out this information?
grizzlyoutlaw
MTN WEST
TACOMA
B0 is Celestial Silver. I would also like any information how to make the swap for my Limited and make sure the key card/remotes won't have issues. Thanks in advance.
I'm going by the dealership tomorrow and will look at some of the lower and sport trims to see if they all have the same handles.
These part numbers are also crossing over to Tundra's also. Take a look at them while your add it.
dholmq
Darren
I want to swap the chrome pieces of my limited door handles to celestial silver. Can someone help me please?
