You’re not wrong but the forums and Facebook pages are a good insight. There are thousands across each media. If you’re only seeing a few out of thousands then that’s an indicator that this is not wide spread. Not a fact but a good sample size to make assumptions.You said 80,000 trucks and 2 failures. I pointed out that not all 80,000 owners post on the various Tacoma forums therefore you don't know if there are more failures that are not being documented on internet forums.
All I was saying is you don't know that only 2 trucks out of 80,000 have the shock issue. Many owners (most) don't even know or care forums exist. If they did these forums would have 80,000 registered users...they don't. Those same owners (that don't post on forums at all ever) could have the problem and we would be none the wiser. That is not my opinion that is common sense.
I wasn't trying to change your opinion, I was pointing out the fact that your data (80,000 with 2 failures) has no basis in fact.
