Someone will need to post to Google docs. It's behind a paywall.Can you link to the TSB document?
I'm in the same situation,truck has been sitting at the dealer for 4 weeks and counting waiting for the part and my VIN is in the TSBAwesome. Mine falls into this TSB. Luckily it's already at the dealer getting the dash ripped out to replace the cracked EVAP core. Good times.
It is the range that may be affected. Lookup your VIN up to the last six numbers. If your last six numbers are smaller than the one on the sheet, then you are part of this TSB. It does not mean yours will fail, just that it may as it happens to be within the range and this is the fix.Is this the list of all VINs that had transmission failures?
Promised I’d post it the second I seen itGlad to see this. A TSB just means that if you take your truck to the dealer with the failure symptoms there is a defined process to get it fixed. Basically it assures you of getting prompt attention and how Toyota will handle it.
Just got my truck yesterday and haven't had time to check to see if my VIN is in range, but super glad to see this happen.
Wonder what the chances are of this turning into a recall/replacement for the affected VINs?
Hate that mine is a part of it and it kinda feels like a waiting game before it detonates. No issues as of yet, but it's not a good feeling just wondering if today is the day.
[/QUO
So the wait is over, nice.Glad to see this. A TSB just means that if you take your truck to the dealer with the failure symptoms there is a defined process to get it fixed. Basically it assures you of getting prompt attention and how Toyota will handle it.
So am I getting this right? If your vin starts starts 3TYLC5....does that mean not impacted then?Just start at the left and take in one digit at a time. Post your VIN if you need help.
Same question, because I'm not sure which VIN to compare mine with. Mine also starts with 3TYLC5 and my last six digits are 005347. But there are no 3TYLC5 VINs in that list. So how do I determine if mine is in or out?So am I getting this right? If your vin starts starts 3TYLC5....does that mean not impacted then?
Wait for it to failVIN #TMLB5JN2RM002132
So if I am reading this correctly, I do fall within the range of vehicles that may have an issue. Does that mean I take it in and get things replaced or do I have to wait until something goes wrong?
