Burgi
NC
24 Taco
I’m in the range but so far my transmission is fine at 9k miles.
Do you need to have one of the check engine codes to get the replacement? Will the codes always pop up or could I still have a code without actually having a check engine light?
frosty4x4
Midwest
Damn I’m in the range. So far no issues but I’m only at 1k. Feels like a ticking time bomb but I guess it’s better to know I’m possibly impacted :wait:
Miqie
2024 TRD Sport-Bronze oxide.
Mine is 3TMLB5JN9RM000992. What's the prognosis?
taco_overlander
east coast
tacoma
steps to figure out if your VIN is in the TSB.
1. your VIN is an exact match to the letters and numbers to the left of the "#" in the TSB list
2. your VIN has a number to the right of the "#" that is less than the number in the matched line found in 1.
if you can do both 1. and 2., your VIN is in the TSB
Thanks @taco_overlander - I was assuming that was the way to read that, but it helps to know for sure.
Good news for some of us, and a more defined fix for the people affected. I know it will make them worry, but at least they will know what is going on.
Tom Sellick
Tom
Ontario
2024 TRD Pro
Definitely! Just heading out from Ontario to Colorado, Wyoming, Utah. A bit of piece of mind!
UG Taco
Curt
St. Louis
SR-5
Here it is guys, official technical service bulletin for the codes that relate to transmission failure
**UPDATED WITH PRODUCTION CHANGE EFFECTIVE VINs**
Steps to figure out if your VIN is in the TSB (by @taco_overlander).
If you can do both 1. and 2., your VIN is in the TSB
Teach a man to fish...
taco_overlander
east coast
tacoma
here is the Tacoma 2024 VIN Decoder that I copied from another site
2024 Toyota Tacoma VIN Decoder
3TM = Toyota Mexico Baja Factory
3TY = Toyota Mexico Guanajuato Factory
J = XtraCab with GVWR below 6000 lbs
K = Double Cab with GVWR below 6000 lbs
L = Double Cab with GVWR above 6000 lbs
B = 278 hp AT (SR5/TRD Sport/TRD Off Road/Limited)
C/F = Hybrid (TRD Sport HV/TRD Off Road HV/TRD Pro/Trail Hunter/Limited)
D = 228 hp AT (SR 8AT)
E = 270 hp MT (SR 6MT/TRD Sport 6MT)
A = XtraCab
5 = Double Cab
F = 278 hp 2WD (SR5/Prerunner/TRD Sport)
H = 228 hp 2WD (SR)
J = 27x hp 4WD (SR 6MT/SR5/TRD Sport/TRD Off Road/Limited)
K = 228 hp 4WD (SR 8AT)
L = Hybrid 4WD (TRD Sport HV/TRD Off Road HV/TRD Pro/Trail Hunter/Limited HV)
N = Tacoma
_ = Check Digit
R = 2024 Model Year
M = Toyota Motor Manufacturing de Baja California Plant
T = Toyota Motor Manufacturing de Guanajuato Plant
The TSB has "B", "D", and "E" in the fifth slot. No "C" or "F" -- so no hybrids are included in the TSB
trailhunger
2024 TH
My TH not on the TSB, but out of curiosity for those of you who are - did you get an update on the toyota app under 'Vehicle Health'?
