Accessing Aux Switch Panel?
StreeTaco
I searched for this topic before posting so hold the blah
To anyone that may know.. in what order do which dash pieces need to be removed to access the back, or to remove the switch panel? Thx
NewtoToyota
Idaho
24 TRD Sport
I had trouble finding something when I did my light install. Eventually I just tried to figure it out myself. With a trim tool I popped off the A/C surround to the left of the steering wheel then you can grab the switch panel and pull it straight out.
I found a couple of YouTubes that show this during the installation of Cali Raised ditch lights.
Do you mind linking one or two here? All the ones I've sort-of found so far spend a ton of wasted time on nothing super important and then skip over the actual removals or reinstall (instead showing they have already removed it or replaced it)
Liking the video, and I had watched the Cali-Raised Light Bar one. But even this one glosses over parts of the process that are new to this vehicle. Example: at 8:42, he jumps in the truck, but already has the dash completely pulled apart. Perfect example of how they are skipping over critical parts of the process and assuming someone already had an elevated knowledge of the tear down on a brand new trim design.
StreeTaco
StreeTaco
lol, I’ve already figured it out. But dang, didn’t take a video
