VIN as it relates to numbers of trucks built
tnjwinters
Tim
2017 Tacoma TRD Pro
So as an example, if the last digits of my VIN were 006000, does that relate to the number of Trailhunter including mine were built to that point ?
JustAnotherDingus
Southern CA
Volvo Wagon (for now!)
Not sure. Mine starts with 009000. I think they’ve built over 100k of the 2024s overall so far? So slightly under ten percent being a halo trim maybe isn’t a weird metric?
Im not sure if that number is by trim, or powertrain though. Or if the bed size plays a factor as well. Maybe someone else knows!
timetoeatpotatoes
A
CA
D:
I think so but I'm making an assumption. The first half of the VIN is what you are getting and the second half is the stock number or how many they have built.
But is the stock number the total for that trim in general? Or total for that specific factory configuration? No idea.
Ruissimo
Rui
New York
I don't think it's the number for a specific configuration. I received one of the first Trailhunters in the country, and my number was 000836. I really don't think there were 835 THs that were built before mine. This is only my opinion, of course. I don't know jack about this.
Vidman
Rick
Mass
My trailhunters vin is 8751 and a build date of 9/11
Each letter of the VIN means something - I’ll dig up the key from TW. But for the trail hunters we are lumped in with other hybrids so it’s not purely trail hunters.
2024 TACOMA VIN DECODER
3TM = Toyota Mexico Baja Factory
3TY = Toyota Mexico Guanajuato Factory
J = XtraCab with GVWR below 6000 lbs
K = Double Cab with GVWR below 6000 lbs
L = Double Cab with GVWR above 6000 lbs
B = 278 hp AT (SR5/TRD Sport/TRD Off Road/Limited)
C/F = Hybrid (TRD Sport HV/TRD Off Road HV/TRD Pro/Trail Hunter/Limited)
D = 228 hp AT (SR 8AT)
E = 270 hp MT (SR 6MT/TRD Sport 6MT)
A = XtraCab
5 = Double Cab
F = 278 hp 2WD (SR5/Prerunner/TRD Sport)
H = 228 hp 2WD (SR)
J = 27x hp 4WD (SR 6MT/SR5/TRD Sport/TRD Off Road/Limited)
K = 228 hp 4WD (SR 8AT)
L = Hybrid 4WD (TRD Sport HV/TRD Off Road HV/TRD Pro/Trail Hunter/Limited HV)
N = Tacoma
_ = Check Digit
R = 2024 Model Year
M = Toyota Motor Manufacturing de Baja California Plant
T = Toyota Motor Manufacturing de Guanajuato Plant
______ = Serial Number[/QUOTE]
