Lets_Taco_Bout_It
Seattle
2024 Bronze Oxide Trailhunter
10/25 - UPDATE:
So after driving in multiple roadway conditions, I have some findings to report. When turning full lock on a hill (up or down) I notice that there is a tiny bit of rubbing, but it sounds like it's hitting felt and not plastic. Also, I noticed that when in reverse, at full turn, there is some kind of vibration, but I need to investigate further with the help of an additional person. I will report my findings next week. I still don't plan on trimming anything, as I'd like to go a few hundred more miles so the location of the slight rubbing is more apparent b/c right now, everything still looks clean.
Another user brought up a good point, if I would want to add snow chains, I would definitely need more clearance. So in the future, I think I will look into an additional lift to provide that.
Lastly, these tires effect mpg greatly in a hilly city environment. I work in downtown Seattle and almost every street is on a hill. The MPG tanked down to 13 mpg when driving in the city, but once I was able to hit highway speeds, it went back up to it's normal range. I noticed that the additional weight makes the truck slow down quite a bit faster. Prior to the KO3 install, on flat ground, I was able to go 60 mph and stay off the gas for a few before giving it extra juice. AFTER the new tires, I noticed that speeds decrease IMMEDIATLY once you let off the gas. This could be due to the fact that they're new and they still need to break in, but I will report back in a few hundred miles if there is any change.
Thanks! Stay tuned!
*Original Post*
Figured I'd update ya'll on fitting 285's on stock Trailhunter wheels. Chris and TJ @Discount Tire in Seattle really took care of this install. No rubbing so far, might remove the crash pad after I take it out on some rough terrain to test any contact. I forsee having to get some aftermarket mud flaps....the OEM ones don't offer much coverage.
BFGoodrich
All Terrain T/A KO3
LT285 /70 R18 127S E1 RWL
BEFORE:
2024 Tacoma *UPDATE* - 285/17/R18 BF Goodrich KO3 tires on stock Trailhunter - before & after photos Image20241024091533
AFTER:
2024 Tacoma *UPDATE* - 285/17/R18 BF Goodrich KO3 tires on stock Trailhunter - before & after photos Image20241024091542
2024 Tacoma *UPDATE* - 285/17/R18 BF Goodrich KO3 tires on stock Trailhunter - before & after photos Image20241024091545
2024 Tacoma *UPDATE* - 285/17/R18 BF Goodrich KO3 tires on stock Trailhunter - before & after photos Image20241024091547
Lets_Taco_Bout_It
Lets_Taco_Bout_It
Seattle
It's amazing the different, more aggressive look a nice set of AT's give the truck. Great choice on the K03's
Absolutely. I'm keeping the other tires for longer out of state road trips and/or the summer months. I heard they're thinner than a normal tire of that size to help offset the cost.
I actually don't know....I don't think there is one. It's truly whatever came with the stock wheels
So this is the *exact* tire I want to put on my stock Trailhunter wheels - thank you so much for posting. You look super close to the crash pad. I’m surprised. Do you think it’ll rub? Keep us posted please.
Can you show a front or back view to show the level of “poke” given the slight wider tire?
These tires weigh 63.9 pounds sadly because there’s no C load option. How is power and braking affected?
How is road comfort? Are they super stiff over bumps? How do they compare in this regard to stock? How about road noise and other handling characteristics?
Do you notice the added ground clearance ?
Why keep the old crappy tires ?
Lets_Taco_Bout_It
Lets_Taco_Bout_It
Seattle
The guys at DT said that if I were to hit a downslope at a turn, there is a possibility of some rub. I'm going to leave it as is to see if I can see any signs of wear after driving for a bit.
In terms of handling, I think I notice a little difference, but not much. The primary difference is obviously vibration from the tread, however, I've read in places that once these get broken in, it smooths out considerably. Stock wheels were very smooth and gave very little vibration feedback.
I'm keeping the stock ones for when I want to head out of state on long highway road trips. Plus, the old ones only had ~700 miles on them....why not keep em. I also didn't switch the spare tire. That is still stock under the truck.
Paul85
J
Kansas
2024 TRD Sport Blue Crush
I know discount tire price matches. Did you pay discount tire prices or find a deal somewhere? I'm looking to upgrade also but think I will go with the 275/70R18 size so there is no rubbing at all. Still have to decide though, yours looks nice.
Lets_Taco_Bout_It
Lets_Taco_Bout_It
Seattle
Yes, they matched WalMarts price. Which was a considerable amount of savings.
2024 Tacoma *UPDATE* - 285/17/R18 BF Goodrich KO3 tires on stock Trailhunter - before & after photos IMG_8229
