frosty4x4
Ok thanks for confirming! Yea it looks really good.It’s +25
Looks amazing !
Looks amazing !
Ok I actually think it’s +20 which surprises me given how little poke I see on OP’s setup. @Snickers i think has more poke on a 285 KO3.Ok thanks for confirming! Yea it looks really good.
Keep us posted. Any rub or wear should be limited to the crash pad felt, which seems fineSo this is the *exact* tire I want to put on my stock Trailhunter wheels - thank you so much for posting. You look super close to the crash pad. I’m surprised. Do you think it’ll rub? Keep us posted please.
Can you show a front or back view to show the level of “poke” given the slight wider tire?
These tires weigh 63.9 pounds sadly because there’s no C load option. How is power and braking affected?
How is road comfort? Are they super stiff over bumps? How do they compare in this regard to stock? How about road noise and other handling characteristics?
Do you notice the added ground clearance ?
Why keep the old crappy tires ?
@Snickers made some small calibrations with 285/75 - maybe it’s camber or other front end suspension settingsIt looks great! What throws me off is some trucks running 285/70 with +25 appear to have more clearance at full lock on stock suspension and others are super close.
Thanks!looks killer !
