Deedzterz
ChicagoLand
Tacoma SR5 Doublecab Longbed
* EDIT * Hello again. I wasn't exactly sure how to edit this post or if I should delete it. I decided to keep it but leave this edit at the top. It brings me sorrow to say that those saying the below "fix" doesn't actually work are correct. !I WAS WRONG! My intention was not to fleece anyone or post bs. My original post was what I thought was correct. However, this morning I saw emails notifying me on posts in this thread and decided to go double check myself. I plugged in my carista app and opened the settings. I turned the speaker volume down to 0 and up to 14 and heard no change in the music being played through the speakers. There was no adjustment of volume. I must deeply apologize to the community. I thought I had found a fix and wanted to share it. I'm not sure what I experienced. My speaker volume was infact much lower before I plugged in the carista odb and much higher after removing it. I'm not sure what the anomaly here is, if it was some type of placebo effect on my ears, some odd jolt in electricity from odb, or just me with my head in my hoohah. I do not mind admitting that I was wrong. I verified my incompetence this morning. The only thing left is for me to attempt to figure out why the volume of my stereo seemed to fix itself. Maybe it didn't. But it certainly sounds much better to me than before when I first got the truck. Again, my deepest apologies to anyone I may have inconvenienced with this post. I will let the moderators decide if it should be marked closed or removed. *EDIT*
Hello everyone,
I am new here but joined for 3 reasons. The first has to do with the title to this thread.
I inherited a 4th Gen SR5 with upgraded JBL speakers back in late November. I immediately noticed how quiet and crappy the sound system performed. Initially, I didn't do any research on the topic. I had a portable JBL speaker in the past and never thought the audio sounded all that great so I just chalked it up to JBL being a low grade audio speaker company anyway. Mid December, I watched a Youtube video searching for a way to turn off the incredibly annoying seat belt chime. I often drive around on private property, at low speeds, with very little need for the belt as I am hopping in and out of the vehicle quite often.
That video is when I found out about an ODB device called "Carista." It is advertised as being able to unlock "secret features" in some car brands and models. Albeit, with a subscription. I decided to purchase it anyway. The device arrived, I plugged it in, and I subscribed to the service. The device and application does as promised. Several nice features were unlocked. I was able to disable the seat belt chimes, enable the windows to be rolled down via the key fob, disable or lower the sensitivity of the front parking alarms, and many more things. Most importantly, I WAS ABLE TO SOMEWHAT FIX THE JBL SPEAKERS!
In the Carista APP, under the special vehicle customizations tab, I noticed an option for MUSIC AND AUDIO. I clicked it. The only object under this setting was called "volume" i believe and it had the numbers 1-10. Mine was set to 3. I turned it to 10. Immediately, I was able to listen to music at a very high volume by having the stereo only set to 20. Before changing this setting in carista, If I wanted the stereo to be somewhat loud, I needed the head unit to be turned up to 60. Going to 60 would now blow out my eardrums. After some time, I decided to settle on setting the option in carista to 8. Now, I turn the volume to 30 or 35 and it is very loud. 50, and I can't hear myself think and my voice is drowned out while jammin along.
I believe these features accessed by Carista can be accessed by a dealership. I have no idea why Toyota would send a dealer a vehicle with global volume setting set to 3 instead of 8 or 9. I could understand not having the global volume set to 10. As I believe a 10 will allow for a completely unfiltered use of the speakers and potentially blow them out. However, I don't think 8 will cause this issue. I have a computer headset with a tuner that operates similarly. I have the option for 1-10 and i set that, then I control the volume level through windows. Maybe Toyota is just playing it safe so it's virtually impossible to cause issues with the sound system? Either way, JBL speakers are not the best. Mid, Treble, and Bass aren't that great and at the pricepoint of 4th gen taco i would expect something like polk audio or boston speakers. I will say, they are sounding much better now after I adjusted this setting. I would reach out to your dealer to see if they can manually adjust this for you. If they don't know what you are talking about, tell them it's in the same system that allows you to enable opening the windows with the key fob. If they try to charge you, I would tell em to "obsenity" off, and just buy the Carista ODB. I believe i got mine on sale for 40 bucks at christmas with a year of access to the application.
**EDIT** I was recalling the location of the setting in the carista app from memory while typing this. It's very possible that setting is found elsewhere in the customizations menu. Please look around.
Those who are wondering... Carista settings changes will stay persistent after cancelling the subscription. You can also use it on as many vehicles it is compatible with as you want.
If anyone has any questions, wants to know more, or needs help with this at all, feel free to reach out to me.
malore
Oregon
2025 Celestial Silver Metallic TRD Off-Road Premium.
Oh wow. I have a Carista. I'm going to look into this ASAP. Surprised I didn't notice it when I was fiddling with my truck last month. Thanks for the heads up!
Deedzterz
ChicagoLand
Absolutely man. Don't forget to turn up the mic sensitivity so you can blow out your friends ears while talking with the window open.
Goriders
2024 Tacoma Sport Plus
Interesting. I may look into this. There are a few of the features I was interested in playing with. I have an OBD scanner but it can’t access the behind the scenes settings.
B-52 Gunner
Gerry
Lansdale, PA
2024 Tacoma TRD Pro
Maybe a dumb question, but can one Carista be shared with other 4G Tacoma owners?
$40 is reasonable but $14.95 per month seems high.
Wondering if I get one and make my adjustments then cancel the monthly, do the new setting remain?
flgator77
St Augustine, FL
2024 Tacoma Off-Road
Hello everyone,
I've had Carista for about four months but only used it once, when it arrived, to change the same settings most users seem to do (seat belt chimes, etc). Based on your post I plugged back in this morning, re-activated my app, and went searching for "special vehicle customizations" tab to get to "music and audio". I can't seem to find either of those tabs, anywhere. Could it be because my truck is a different trim level (OR Premium)?
Yes, they are not VIN locked.
Drifte
Colton
Iowa
24 tacoma trd offroad
Its odd some people have this problem. My JBL is loud at just volume 24. I use lossless audio with apple music, on a samsung galaxy s25 ultra. Its not perfect but its certainly better than Pandora. I like JBL, I spec them for many jobs. Just like the tires on a new car though, you get a different line of equipment from the manufacturer.
rkohlerbend
Rob
Bend, Oregon
2024 iForce Max Limited
This is great info! That said, JBL is not a low end audio company. Just the opposite.
dknelson
Don
Oberlin, OH
2024 Tacoma TRD Off Road
I have the OR Premium also. It shows no music and audio listing under customizations. I did find under the display and navigation tab, or something like that, settings for mic sensitivity and one for speaker volume. Speaker volume is adjustable from 1 to 14. Mine was all the way up. I may have set it there months ago when I initially looked. Perhaps that’s why I’ve really had no complaints with the volume.
Deedzterz
ChicagoLand
It's quite possible that the setting I'm talking about was adjusted previously to your purchase. I don't know if they leave the factory with different settings or maybe your dealership had a mechanic who knew about it. Lots of possible explanations. Especially when some people have the issue and others don't. I once had a 30 dollar headset for my computer. I thought it was amazing. Then I was gifted a 150 dollar headset and learned that I was wrong about the first headset. Some people might have the issue but aren't even aware of it.
Drifte
Colton
Iowa
Oh absolutely. I will have to plug into the truck and see what I find for settings. I like the system though for the most part. I think it will benefit from some sound treatment, and maybe a dsp down the road to control things to my liking. But I definitely get the: you dont know what your missing until you try it. I design a/v systems and typically use JBL speakers in commercial applications over other options. But occasionally or even often someone bids with an "equal" alternative thats much cheaper and at demo time it falls short.
rougesix29
Oregon
2024 Toyota Tacoma sr5
Not activating certain features are what stealerships do to make extra money on the sales end. I also have 2 BMW’s and they do the same thing but charge a heck of a lot more to activate. I use a computer and wireless odb to change all kinds of settings or unlock cool features. They hide stuff on standard models so when you buy a TRD or TRD PRO it’s turned on. Video in motion is a prime example for a lot of cars.
evlfred
Monte
Idaho
Where exactly in Carista is this setting? I can’t seem to find it.
