JBL sound system low volume out of the door speakers
I have not heard of any problems caused by this amp. They have made them for just about every Toyota product produced for some time, so I think we would have heard about that by now.
It is easily removed if there is a problem. Take it out, plug back in the factory connectors and they would never know it had been there. The only common changes that trigger warranty problems tend to be changes to the suspension, like lifts.
Nor Cal
2024 TRD Off Road Long Bed
My 2024 truck has the same issue. The door speakers barely make any sound. If you put the mix to the rear you have to crank the volume to almost max to hear it in a normal way, and it's still not that loud.
Has anyone found a fix? And the argument that it's loud enough overall is missing the point....
Biggs1975
Joe
Virginia
2024 Trailhunter
The only thing I have found to kind of help is the Beatsonic amplifier. I hooked it up the first time and didn't think it was doing anything but later found out it was me not havingthe settings right. It just boosts the volume. I also have the fader pushed to the back a couple notches on the Toyota settings. It's still not what I would consider a premium sound system.
I agree with @Biggs1975 on the Beat Sonic amp. I have had that amp for a month now and have listened to more of my music and I am liking it more than I did at first. It lets you push the soundfield back and recover the lost volume to have a better soundfield and still have adequate sound levels.
From my perspective it is the best upgrade you can hope for unless you just replace the whole system with a truly premium sound system at a huge cost.
Biggs1975
Joe
Virginia
2024 Trailhunter
Thanks for the feedback, guys. It's hard to understand why Toyota sent it out the door like this...
Another thing I found that helps also is to set your equalizer on your phone, assuming you are streaming music to balanced or keep everything in the middle. I then use the Toyota settings to adjust the treble, midrange, and bass. It's a disappointment in my opinion but the only other option is to start from scratch with a new system.
SilverSurfer
Tacoma TRD OR Premium Plus
This comes up alot. Here's the non beatsonic fix.
1. Move the sound bias 75% to the back.
2. Play music at 50-55 volume. Not percent, turn it up until teh volume shows 50 or more.
Now you will have a more balanced sound field and you will be able to hear it.
Nor Cal
Thanks, I'll give it a shot. I'm glad for this forum; I was going to take it to the dealer to have them look at it. I'll save my time....
Pootklopp
Usa
2024 Bronze Oxide TRD OR
I'll add two things I noticed while playing around. For me (Google Pixel 6 pro) having no EQ turned on gave me the best results. I tried the default YouTube music EQ and one from the play store. Both made my sounds worse. Music sounded lower and muddled no matter what frequencies I adjusted.
I pretty much never go above 40 volume. Podcasts on the highway get around 40. Music that high would be too much. I would say I have normal to pretty good hearing for reference. I wouldn't be surprised if encoding/phone brand played a role in sound differences.
Have people tested media from USB to compare vs phone?
Deedzterz
ChicagoLand
Tacoma SR5 Doublecab Longbed
I posted a thread in the same area of the forums regarding a FIX for the JBL speakers that does not require you to install a 3rd party tuner.
