Cali Raised LED
Jake
Fort Worth, Texas
4th Gen Tacoma
Welcome
Cali Raised LED
www.CaliRaisedled.com
Phone: 888-385-5036 l Email: [email protected] l Instagram: @cali_raised_led
https://caliraisedled.com/collections/2024-toyota-tacoma-oem-switches
Trying to wire up some lights to your aux switches in your Tacoma? We've got you taken care of! Higher trim models like the TRD Off-Road, Pro, and Trailhunter are equipped with aux 1-3 right on the dash. Here's how to wire it! If you have questions regarding the installation please contact customer service at 888-385-5036, or [email protected]!
FEATURES:
  • Easy installation, modifications required. You will need to make the electrical connections. *Watch the how-to install OEM switch video for more details.
  • Compatibility with ANY LED wiring harness, best paired with Cali Raised LED wiring harness, sold separately.
  • Made to fit existing factory openings.
  • Laser-etched symbols.
Install Video
Aux & Switch Install Video
Duce95
Big Deezy
Arizona
2024 TRD Off-Road Premium
That’s great. What about wiring of your switches to replace the oem aux switch? I would like to replace my aux switches with some of your laser etched options.
Irvin
JC
23 Outback
Good to see the new video out... But, without me having to watch it yet, is it completely plug and play with my aux wire harnesses yet or do I still need to splice? As soon as it's plug and play I'll order my ditch light kit.
Cali Raised LED
Cali Raised LED
Jake
Fort Worth, Texas
4th Gen Tacoma
Thank you for your interest and feedback! To clarify, it's technically 50/50. The kit is designed to plug directly into the auxiliary switches, so you won’t need to connect it to the battery or use an additional wiring harness. However, you will still need to splice or create a connection between the light and the open wire from the plug that controls Aux 1, 2, or 3. Unfortunately, due to the nature of auxiliary switches, a 100% plug-and-play solution isn’t likely, but we've worked to make the process as straightforward as possible. Let us know if you have any other questions
robfultz
Rob
2024 Tacoma Off Road
Anyone know how to get into the switches in the center console?
I believe the panel around the shift lever just pops up but not sure I want to start prying it up without some input from others.
Gear_yyc
I believe the panel around the shift lever just poops up but not sure I want to start prying it up without some input from others.
I dunno - I'm really hoping nothing in my truck poops :cwl:
Kielly
Ryan
Alberta, Canada
2024 Tacoma Sport+ 6M
I'll have to take a look at this when I'm home and can actually listen to it.
Can't remember how I wired them up but I remember the last time I was messing with my pigtail for the AUX buttons I noticed I had three wires coming from the ditch lights, one wired to ground, one wired to aux 1 and one wired to aux 2 for whatever reason.
Anyways I remember that one of the wires I unplugged, wether it was aux 1 or 2, ended up being completely useless so I just left it unplugged.
Had me scratching my head until I threw my hands in the air and said whatever, don't fix what isn't broken lol
Suzay
Hawaii
2024 Tacoma sport
I put a caliraised switch there just for looks. There is an extra connector in there so I connected it and it lights up but does nothing. I am planning on routing my fang lights to that switch in the center console as soon as I get a part in.
robfultz
Rob
does the part around the shifter just pop up?
I’m trying to figure out how to get to the back of those switches in the console
Suzay
Hawaii
2024 Tacoma sport
You have to go to the corner of the console and pop it up. There are clips on each corner. And if you want to completely remove it the shift knob does come off with a small metal pin you push to the right and a connector for the dial that needs to be unclipped.
