OK, so I just received my AMP Research powerstep from Real Truck to install on my 4th gen Sport. The installation took awhile and then when I got to the part in the manual to connect the OBD plug to the truck's wiring system there is nothing in the install manual that tells or shows you which wire to splice into. It says blue and white wires, but the problem is that there are 5 white wires and several blue ones. Called Real Truck and they were unsure but assumed which two. I tried their suggestion, but didn't work. Now I have to wait for their engineering folks to email be back some day. So, the frustrating part is my truck is all torn apart now and the assume wires appear not to work. Has anyone else done an install yet and has any information on the correct wiring..
Thanks
Thanks
