Damn..............you should go into business as a Toyota tech! I'd trust you over any dealer concerning this issue.This isn’t the only vehicle to have this problem- GM 5.3 engines did this for quite some time, the fix was to flash the ecu to pulse the electrical current to the compressor clutch, and to install a stronger belt, manufactured by gates rubber co. They may have also added a tensioner that was stronger.
as to your issue, the alternator has a sprag clutch type/overrun pulley. The technician could have misdiagnosed the problem assuming the sprag wasn’t doing it’s job/ accommodating aggressive drag that occurs in a sharp period, like when an ac clutch is activated, or when an engine is shut off. The technician could have removed the belt and spun the pulley by hand to diagnose the sprag pulley….. if the compressor clutch is definitely causing the chirp, spray the serp belt with a spray bottle of water on the ribbed side of the belt-when the engine is not running. Then, start the engine and get the ac compressor to engage… use a piece of heater hose like a stethoscope to verify chirp location. If the belt is louder after being wet and running the ac compressor, it is almost always a belt tension issue. By disconnecting the harness connector to the ac compressor, you can eliminate the resistance from the clutch being engaged by denying the clutch electrical current. If the noise goes away, then the belt is slipping in the compressor clutch pulley. Some never vehicles do not have mechanical tensioners but rather, use a belt that tensions itself. If this is the case, the quickest fix would be to throw a new belt at the engine, or if the Engine has a mechanical tensioners, have a new tensioner installed- then verify repair… if it still makes noise, applying Coca Cola to the belt helps, but risks being rinsed away in time. When the coke dries, it is tacky.. I have seen belt “glue” dressing cause aero belts to melt into the pulleys, so I don’t advise it. I deal with belt noise issues all the time at my work- seldom it is the belt unless it is worn out usually the mechanical tensioners is worn out and not applying as much tension/force, onto the belt circuit- sometimes their is an alignment problem… when apply water to the belt, if the noise get quieter- it is an alignment issue… except these darn new fangled self tensioning belts are different. If you have any more questions, do not hesitate to ask me… again, I deal with this stuff all the time. Good luck!
