guitarist alec
Alec
california
Finally picked up the Yakima Overhaul Rack & Retrax Pro Tonneau locking cover with the black Friday discounts.
The locking cover gives the option of loading up my gear a day before going out early on a big job, and the lock gives me peace of mind it will all be there in the morning.
Truck still looks sporty ~ the black rack is a nice upgrade from the silver Thule rack I had one my 2012 Gen 2. 😊🛻😊
2024 Tacoma Bed Rack & Tonneau combo: Yakima Overhaul Rack & Retrax Pro Locking Tonneau IMG_6138
2024 Tacoma Bed Rack & Tonneau combo: Yakima Overhaul Rack & Retrax Pro Locking Tonneau IMG_6137
guitarist alec
guitarist alec
Alec
california
PS - WARNING ‼
with the Retrax Pro Tonneau Cover the Tacoma OEM rail tie down anchors no longer fit . . . so . . . I guess I’m going with the Charvonia ones next time they go on a sale !
TheGreatWhiteNorth
Alaska
2024 SR5
Im looking at it, trying to figure out how the tonneau opens? Doesnt look like a trifold. Does the whole thing pivot up?
Im looking for racks exactly like that, which will fit the OEM trifold tonneau
Benny
Jay
Oregon
I believe that brand rolls under….
Fattirz in NC
Brian
Charlotte, NC
2002 F-150 SuperCrew
Think roll-top desk…. Top rolls up inside towards the cab.
guitarist alec
guitarist alec
Alec
california
Looks really good:thumbsup:
Where did you order from?
The heavy rains have come and since I broke my collarbone I had it installed at the truck store here in NorCal, called CAMPWAY
it worked great this weekend for work 👍🏼
2024 Tacoma Bed Rack & Tonneau combo: Yakima Overhaul Rack & Retrax Pro Locking Tonneau IMG_6136
nurp42
TRD PreRunner
'24 PreRunner
PS - WARNING ‼
Other than needing to change the anchors, are the bed rails still useable for low-profile accessories that fit under the cover? Sorry to have not asked this in my earlier inquiry, but didn't think of it at the time.
guitarist alec
guitarist alec
Alec
california
@nurp42 -yes, I suspect they are… It's just that The Toyota bed anchors have to be put in sideways and then turned horizontal to lock down… And when you try to put them sideways, they conflict with the Tonneau ... I'm planning on getting bed anchors that don't install that way 👍🏼
nurp42
TRD PreRunner
'24 PreRunner
Thanks again for the info---- was curious if something was free to move along rail without obstacles blocking travel and evidently that's the case as the problem w/ OEM tie-downs was due to attachment rather than movement.
emidyl
Henry
Toronto
N400 Sport Prem
Its basically a garage door flipped on one end with a canister, the Pro is the best one out there for retractables. RealTruck is the main supplier and one of their brands. I looked into it and went a different route with a hard roll up, also from RealTruck.
nurp42
TRD PreRunner
'24 PreRunner
Did you have a specific reason to go w/ roll-up vs retractable? Can the one you got be used together w/ the bed rack?
emidyl
Henry
Toronto
N400 Sport Prem
personally I kinda liked the way it operated, and it was also $1k cheaper in Canada. You also don't lose that space by the cab that the canister takes up. And not seeing that there would be too many issues with the roll up as it's quite simple in design. The retractable concerns would be the actual mechanism as well as debris getting into the canister from its roll in entry point. However it does have a lifetime from RealTruck, so theres that.
nurp42
TRD PreRunner
'24 PreRunner
Thanks for the follow-up. The primary feature that I'm looking for is being able to use it w/ the bed rack like the OP has done. While there do seem to be some disadvantages of the retractable cover, if other options don't allow for rack integration, it wouldn't be a good fit for my purposes.
