Front Of Truck Bed Holds Water and Doesn't Drain
Tacorey
Corey
Atlanta, GA
2025 Tacoma TRD Offroad; 2007 Infiniti M35
My truck has the spray in bed liner from the factory. I was wondering if anyone else has this issue? I backed my truck into my driveway which is on a slope, and when I looked at it after rain the next morning, the bed was full of water. Like 3-4 inches. I'm pretty sure that's not supposed to happen, so I'm wondering what I should check.
There are drain holes in the composite bed without the bed liner. You should be able to find them and clean them out.
AltarBoy
Ryan
New york
21trd off-road
I also have a factory spray in line. At the front of the bed should be 4 or 4 small drain holes spread across the front
TxGlenn
Glenn
Spring, TX
2024 TRD Sport
Can you see the drain holes? If the are not there for some reason you can re-drill them.
4g hybrid
I have factory spray in. As stated, it came with drilled holes (I had 3 of them, left center right, each 1/4" in diameter).
They are missing, just take a drill and high speed bit and create a few. Just take your time so it's clean. I drilled two new ones at 1/2" diameter to be able to slip my tonneau drain tubes straight down and through.
MERAKIAUTOWORKS
Joshua
Anaheim, CA
I have the same issue, I might have to see if theres any holes.
-Josh
Tacorey
Corey
Atlanta, GA
-Josh
Mine doesn't look like it has holes??? Can someone take a picture of where their holes are so I know where to drill? Probably going to have the dealer do it at first service because I'd rather them be on the hook if they mess up the bed liner.
