Supertech1
Arkansas
2024 Tacoma TRD ORP
Do you know how much lift is on the PRO and TH versus the Sport and OR? Your truck has the perfect stance.
There are likely others on this site more qualified to answer the lift question. My experience does not match what I’ve read. I’ve measured the front end difference between the TRD OR and TrailHunter @ 2”, hub center to bottom of fender flare.
According to what I read, the Fox suspension on the Pro adds 2” lift, the TrailHunter OME suspension adds 2.5” lift.
My experience was the opposite, with the Pro having slightly more lift. It was a noticeable difference to me.
The automaker has equipped the TRD Pro with TRD-tuned FOX QS3 shocks that offer a 2-inch lift and adjustable compression stiffness, combined with reinforced rocker protection for high-speed runs and jumps. It also comes with Toyota’s multi-terrain select, crawl control, a locking rear differential, and a front stabilizer bar disconnect, making it versatile for driving in different conditions.
Toyota has built the Trailhunter for overlanding with its Old Man Emu 2.5-inch monotube suspension, which increases load-carrying capacity and impact absorption on long journeys.
MT-Taco is correct., +25 with 8.5” width is now available At the time I purchased, the +12 17x 8” was the only option. The 8” wheel vs 8.5” makes a slight difference as well.
If I’m not mistaken, the TH wheel is +20? Atleast that’s how mine are stamped.
These are the only pics that might help. Sorry, I don’t have a good straight on picture showing the poke. There was very little difference between the stock tire/wheel
This looks good. I may go for the +25 8.5” wheel. Any idea what difference it makes in the tire look with 8” vs 8.5”?
1/4 inch more wheel poke. I’m willing to bet if you had an 8 mounted across from and 8.5 you wouldn’t notice a difference. 11 inch or wider tire go with the 8.5? Narrower go with 8? Just my opinion.. Right or wrong
toyota4x482
South Carolina
2024 TRD Sport 6MT Premium
Thank you for that detailed explanation! You seem very knowledgeable on the subject.
I guess I need to target 2-2.5” of lift.
I keep keep seeing posts on the new TRD OEM lift coming factory on trucks but I have yet to find the lift for sale. If possible, I would like OEM over aftermarket.
thanks for replying.
dapperdan
WI
2024 Tacoma off road
Looks great! How is your MPG with that setup?
Honestly don't check it much, and I have had the stocks back on for winter here in WI, so will get a better idea once the weather warms up.
Devildog81
minnesota
2024 tacoma trd offroad
Any updates on MPG's?
Looks like a winning combination.
When you get right down to it there aren't all that many good AT tires available in the sub 50lbs range in this size, especially with 3pms winter rating.
These and the Nokian Outpost nAT are both on my shortlist.
Thanks for sharing, looks badass!
Have you looked at the Nitto Terra Grappler G3’s? They are 48#s I believe and also are a 3 peak rated tire. I’ve got a set on order and should have them on the truck next week.
GDobbins
Graham
2025 Trailhunter
Yes, they will fit. Brake caliper clearance is not an issue. I ran these (1500 mile) on my TrailHunter for a hunting trip in November.
What wheel are you running? Looks great.
